Hello everybody,
I wanted to ask if there is a possibility in pgRouting to generate routing descriptions?
I found these links:
Also, I only found this article on the wiki page of PgRouting. The entry is from 2014.
Is there a feature in PgRouting that generates Driving Direction Instructions?
Can you help there?
Many Thanks
Robert
Hi Robert,
The wiki page link represents the current state of driving directions in pgRouting. As I mentioned the process is straight forward, but the details are very dependent on a users specific data. I implemented it a long time ago for a client's specific data schema, OSM and Google only have to deal with they one data schema, pgRouting allow every user to have different data schema so it is not likely a "generic" solution will be easy to find.
So that leaves you with with a couple of options:
1. building a solution specific to your data schema along the lines outlines
2. having someone else build it for you
3. using and existing solution like OSM and loading your data into that
4. not having a solution
Contact me off list if you want to consider some contract help. If you want to do it yourself, I'm happy to help if you get stuck but read through wiki link again because that is the model you need to follow.
Best regards,
-Stephen Woodbridge
On 2/12/2019 4:37 AM, Robert k wrote:
Hello everybody,
- https://gis.stackexchange.com/questions/20117/does-pgrouting-support-turn-by-turn-routing
There are many dead links in the article.
- https://lists.osgeo.org/pipermail/pgrouting-users/2011-January/000537.html
- https://github.com/pgRouting/pgrouting/wiki/Driving-Direction-Instructions
Can you help there?
Many Thanks
Robert
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Robert,
No there is no driving directions built in pgrouting. The wiki page is the best description on how to build one.
-Steve
ยทยทยท
On Feb 12, 2019, at 4:37 AM, Robert k <kwo_bo@outlook.com> wrote:
Hello everybody,
Can you help there?
Many Thanks
Robert
Hi Steve,
Yes thanks for the tip. I was well informed.
In addition, I have looked at the angle calculation of GraphHopper or OSRM and now have a routing description that meets my requirement.
Too bad the PG routing does not give default routing instructions, similar to OSRM or GraphHopper.
Maybe there will be such considerations in the near future
Best regards Robert
Am 02.07.19 um 19:10 schrieb Stephen Woodbridge:
Robert,
-Steve
Sent from my iPhone
On Feb 12, 2019, at 4:37 AM, Robert k <kwo_bo@outlook.com <mailto:kwo_bo@outlook.com>> wrote:
Hello everybody,
Can you help there?
Many Thanks
Robert
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
