We are developing an web application that users PostgreSQL 8.4 + PostGIS1.5 + Pgrouting 1.03 + development using (Java + Struts + Hibernate)
When this Query is executed:
SELECT ST_AsText(the_geom),id AS Coords FROM delhi_road WHERE id IN (SELECT edge_id FROM shortest_path_astar(‘SELECT id, source, target,x1,y1,x2,y2,cost,reverse_cost from delhi_road’,550,662,true,true))
We are getting the below mentioned error and the other users accessing the application were too facing the database exceptions. Can someone help us to fix this issue.
Error from the postgreSQL query
ERROR: Error computing path:
********** Error **********
SQL state: 38001
Query used:
Error on the Application server (IDE)
[ INFO] 46:48 (MapServiceDAO.java:generateRoute:1525)
Query is…SELECT ST_AsText(the_geom),id AS Coords FROM delhi_road WHERE id IN (SELECT edge_id FROM shortest_path_astar(‘SELECT id, source, target,x1,y1,x2,y2,cost,reverse_cost from delhi_road’,550,662,true,true))
[ INFO] 46:48 (MapServiceDAO.java:generateRoute:1552)
Exception aala…org.postgresql.util.PSQLException: ERROR: Error computing path: _
Feb 22, 2012 11:46:48 AM org.apache.catalina.core.StandardWrapperValve invoke
SEVERE: Servlet.service() for servlet GenerateRoute threw exception
org.hibernate.SessionException: Session was already closed
at org.hibernate.impl.SessionImpl.close(SessionImpl.java:303)
at com.tis.hib.util.HibernateSessionFactory.closeSession(HibernateSessionFactory.java:86)
at com.tis.dao.impl.MapServiceDAO.generateRoute(MapServiceDAO.java:1572)
at com.tis.servlet.GenerateRoute.doGet(GenerateRoute.java:125)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:261)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:581)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
Palatla Srikanth
