Yes, the nice work that GreenInfo did for us with pgRouting notes the following:
-- Install PostGIS and PgRouting
-- For the most part PgRouting works fine with PostGIS 2.0 but I did need to fix some function names as noted below.
-- Changes to routing_core_wrappers.sql
-- * replace "length::double precision as cost" with "cost"; the cost field is now required but we can weight routes by something other than length
-- * fixed numerous references to X() and Y() and SRID() and SETSRID() and STARTPOINT() and ENDPOINT() to use the ST_* versions
-- Changes to routing_topology.sql
-- * assign_vertex_id() call to addGeometryColumn() now uses 3 dimensions instead of 2
The last of these is because we are using 3D shapes to get terrain profiles for our trails... .
Best,
Steve
Stephen V. Mather
GIS Manager
(216) 635-3243 (Work)
clevelandmetroparks.com
________________________________________
From: pgrouting-users-bounces@lists.osgeo.org [pgrouting-users-bounces@lists.osgeo.org] on behalf of Jelmer Baas [baas@speerit.nl]
Sent: Tuesday, March 12, 2013 3:20 PM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] ERROR: function startpoint(geometry) does not exist
I tried this a while back, and found that it's not all that much work to re-write the functions to support Postgis 2.0: the only requirement was adding 'ST_' to all most calls.
Jelmer
-----Original Message-----
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Stephen V. Mather
Sent: Tuesday, March 12, 2013 19:32
To echo Stephen, in my experience, running the legacy.sql file against your database eliminates all the compatibility issues.
Best,
Steve
Stephen V. Mather
GIS Manager
From: pgrouting-users-bounces@lists.osgeo.org [pgrouting-users-bounces@lists.osgeo.org] on behalf of Stephen Woodbridge [woodbri@swoodbridge.com]
Sent: Tuesday, March 12, 2013 2:13 PM
To: pgrouting-users@lists.osgeo.org
Right you are using postgis 2.0 and the tutorial was written for postgis
1.5.x
You might solve some of these problems but installing legacy.sql.
google: postgis 2.0 legacy.sql
-steve
On 3/12/2013 1:56 PM, maruf rahman wrote:
Hi
I am in section 5.2 of thistutorial <http://workshop.pgrouting.org/chapters/topology.html>\.
When i run this command
SELECT*//* assign_vertex_id('ways', 0.00001, 'the_geom', 'gid'*//*);*/
i get the following error/*
pgrouting-workshop=# SELECT assign_vertex_id('ways', 0.00001, 'the_geom', 'gid');
NOTICE: CREATE TABLE will create implicit sequence "vertices_tmp_id_seq" for serial column "vertices_tmp.id <http://vertices_tmp.id>"
CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
LINE 1: SELECT gid AS id, StartPoint(the_geom) AS source, EndPoint(t...
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT gid AS id, StartPoint(the_geom) AS source, EndPoint(the_geom) as target FROM ways
CONTEXT: PL/pgSQL function "assign_vertex_id" line 27 at FOR over EXECUTE statement
Seems like I am missing the startpoint(geometry) function.
How can I fix this?
Thanks
Maruf
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
