I am trying to add a function: 1-to-many dijkstra shortest path.
Thus I downloaded the last git and added a folder named 1toNsp in “extra”, which contains tomanysp.h, tomanysp.c and boost_wrapper_tomany.cpp.
These files are highly inspired from the dijkstra.h, dijkstra.c and boost_wrapper.cpp files that are in the “core” directory.
-actually for now it’s mainly a copy/paste of them-
I also created a .sql in extra/1toNsp/sql to define the function onetomany_dijkstra_shortest_path(text, int, int array, boolean ,boolean).
I checked if this function exists by returning the distance between source and the first target only, using boost_dijkstra; this works well \o/.
Now I want the (static int compute_tomany_shortest_path(char* sql, int start_vertex,
int *end_vertices, int nb_targets, bool directed,
bool has_reverse_cost,
path_element_t **path, int *path_count)) function to call a function defined in boost_dijkstra_tomany.cpp (named boost_dijkstra_tomany(…)).
Problem is that when I call
routing=> SELECT * FROM onetomany_dijkstra_sp(‘SELECT gid AS id, source::int4,
target::int4, length::double precision AS cost,length::double precision
AS reverse_cost FROM ways’, 3, ‘{7,18,179}’, true, true);
I get
ERROR: could not load library “/usr/lib/postgresql/9.1/lib/librouting_tomanysp.so”: /usr/lib/postgresql/9.1/lib/librouting_tomanysp.so: undefined symbol: boost_dijkstra_tomany
This function (int boost_dijkstra_tomany(…)) is declared in tomanysp.h and called from tomanysp.c; while it is defined in boost_wrapper_tomany.cpp (which #includes “tomanysp.h”); once again it looks the same as what is done with dijkstra.h, dijkstra.c and boost_wrapper.cpp.
my /extra/1toNsp/src/CMakeLists.txt is :
SET(LIBRARY_OUTPUT_PATH …/…/…/lib/)
ADD_LIBRARY(routing_tomany SHARED boost_wrapper_tomany.cpp tomanysp.c tomanysp.h)
INSTALL(TARGETS routing_tomany DESTINATION ${LIBRARY_INSTALL_PATH})
Could someone tell me what I am missing?
Using postgresql 9.1 with ubuntu 11.10.
