Hello Daniel,
i've run into the exact same error message today and in fact, my geom column is MULTILINESTRING.
Did i have to convert my edge geom to LINESTRING for using them proper in pgRouting?
Sincerely,
Julien
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
Hi Bob,
The error complains, that "st_isRing(st_linemerge(geom))" should be
called on LINESTRING geometries only.
What is your geometry type of your "geom" column?
Is it MULTILINESTRING?
Best regards,
Daniel
On 06/10/15 06:07, Bistrais, Bob wrote:
> I am trying to build a statewide road network for analysis with
> pgRouting. I ran pgr_createTopology, and it reported OK.
> Next I tried to run pgr_analyzeGraph, and got an error.
> Here is the command I input:
> SELECT
> pgr_analyzeGraph('ng_roads',0.0001,the_geom:='geom',id:='gid',source:=
'sourceroute',target:='targetroute');
> And here is the error message:
> NOTICE: Analyzing for ring geometries. Please wait...
> ERROR: isring() should only be called on a LINE
> CONTEXT: SQL statement "SELECT count(*) FROM public.ng_roads
> WHERE true AND (true) and st_isRing(st_linemerge(geom))"
> PL/pgSQL function pgr_analyzegraph(text,double
> precision,text,text,text,text,text) line 309 at EXECUTE statement
> -What should I do about this? Can I still perform pgRouting
> analysis with these roads?
> _______________________________________________ Pgrouting-users
> mailing list Pgrouting-users@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
- -- Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iQEcBAEBCAAGBQJWEuv4AAoJEHjh5kk/zBG0U1IH/A2TLaBaraKBnQjW6ksynLHl
KI/Z3Ekp16Lb1jz6J8ksjjtrl8wDvTOxhG/YsuJdqpoSYGQd2c5oshpulZw/T+xt
M10fp4q2OQ2yTIIzRrk+B7iUSImfYkQVA5RBMOhI3NFXX2K1Dvoc9r6YJs5/tCxK
1vGDOxF9FMjVhP45GAxnq/tw4LzKQEqeUYVICZBL4k/dSvHDcu+KyerhzCOG2HJV
Lida2wOxAs/T0kJ7J/K+xQdeKu0ZiZLUH6+jIlsb0arYg+UUdkPnI7BfvL+uo9ds
0jheeYdknAVB4rqJrlBypjfuNMBY47Dmfj1DTJyymFduRd4J1gKHKYPiUIO+QBc=
=ih9I
-----END PGP SIGNATURE-----
Pgrouting-users mailing list
