Hi . Can someone help me ?
When i execute :
psql -f /usr/share/pgrouting/routing_dd.sql routing
I get this error :
psql:/usr/share/pgrouting/routing_dd.sql:27:
ERROR: could not load library “/ usr / lib / pgsql / librouting_dd.so” libCGAL.so.2: Failed address (mapping) segement of the shared object: Permission denied
Note : all is wright for
/usr/share/pgrouting/routing_core.sql
/usr/share/pgrouting/routing_core_wrappers.sql
/usr/share/pgrouting/routing_topology.sql
/usr/share/pgrouting/matching.sql
/usr/lib/pgsql/librouting_tsp.so
/usr/share/pgrouting/routing_tsp.sql
/usr/share/pgrouting/routing_tsp_wrappers.sql
Thanks .
When i execute :
I get this error :
ERROR: could not load library "/ usr / lib / pgsql / librouting_dd.so"
Permission denied
This sounds like the permissions or ownership issues on the file and need to set them correctly. On my Debian Lenny system I have:
woodbri@mappy:/u/www/html/routing/leaddog$ locate libCGAL
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
/usr/lib/libCGAL.so.1
/usr/lib/libCGAL.so.1.0.1
/usr/lib/libCGAL.so.2
/usr/lib/libCGAL.so.2.0.1
/usr/lib/libCGALPDB.a
/usr/lib/libCGALPDB.so
/usr/lib/libCGALPDB.so.2
/usr/lib/libCGALPDB.so.2.0.1
/usr/lib/libCGALQt.a
/usr/lib/libCGALQt.so
/usr/lib/libCGALQt.so.2
/usr/lib/libCGALQt.so.2.0.1
/usr/lib/libCGALcore++.a
/usr/lib/libCGALcore++.so
/usr/lib/libCGALcore++.so.2
/usr/lib/libCGALcore++.so.2.0.1
/usr/lib/libCGALimageIO.a
/usr/lib/libCGALimageIO.so
/usr/lib/libCGALimageIO.so.2
/usr/lib/libCGALimageIO.so.2.0.1
woodbri@mappy:/u/www/html/routing/leaddog$ ls -l /usr/lib/libCGAL.so*
lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so -> libCGAL.so.2.0.1
lrwxrwxrwx 1 root root 16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 -> libCGAL.so.1.0.1
-rw-r--r-- 1 root root 173672 2007-03-25 17:03 /usr/lib/libCGAL.so.1.0.1
lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 -> libCGAL.so.2.0.1
-rw-r--r-- 1 root root 215664 2008-06-23 08:02 /usr/lib/libCGAL.so.2.0.1
You should have something similar. You might try something like:
sudo chown root.root /usr/lib/libCGAL.so*
sudo chmod 644 /usr/lib/libCGAL.so.2.0.1
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Sorry but i get always the same error.
Thanks
2011/8/16 Stephen Woodbridge <woodbri@swoodbridge.com >
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so → libCGAL.so.2.0.1
lrwxrwxrwx 1 root root 16 2007-11-25 18:19 /usr/lib/libCGAL.so.1 → libCGAL.so.1.0.1
-rw-r–r-- 1 root root 173672 2007-03-25 17:03 /usr/lib/libCGAL.so.1.0.1
lrwxrwxrwx 1 root root 16 2009-03-24 19:34 /usr/lib/libCGAL.so.2 → libCGAL.so.2.0.1
-rw-r–r-- 1 root root 215664 2008-06-23 08:02 /usr/lib/libCGAL.so.2.0.1
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
dkastl
August 17, 2011, 11:04am
4
Hi Jules,
Can you make sure that CGAL is installed at the right place?
If you have compiled pgRouting yourself, which OS and architecture do you use?
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
I have compile it myself.
Centos 5. 5 (Linux version 2.6.18-238.19.1.el5 (mockbuild@builder10.centos.org ) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-50))
2011/8/17 Daniel Kastl <daniel@georepublic.de >
Hi Jules,
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
dkastl
August 17, 2011, 11:55am
6
You could also try the package of the ELGIS repository:
http://elgis.argeo.org/
And if you want to compile yourself, take a look into the .spec file that is inside the .src package:
http://elgis.argeo.org/repos/testing/5/elgis/SRPMS/repoview/pgrouting.html
Hope that helps,
Daniel
Hi Jules,
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
Thanks Daniel
How can I know that pgrouting is correctly inslalled
Jules ?
Hope that helps,
Daniel
Hi Jules,
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
dkastl
August 17, 2011, 10:44pm
8
Hi Jules,
First of all you shouldn’t get errors when loading the pgRouting functions.
This here is a script to make a PostGIS and based on that a pgRouting template database:
https://github.com/pgRouting/workshop/blob/master/bin/create_templates.sh
It’s only tested on Ubuntu, so on CentOS you might have to adjust the paths at the beginning.
And you can remove the “–quiet” flags to be able to read the full console log.
Daniel
On Thu, Aug 18, 2011 at 12:20 AM, Jules Kouadio <sekedoua@gmail.com > wrote:
Thanks Daniel
Jules ?
Hope that helps,
Daniel
Hi Jules,
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
Hi daniel.
Can I know how to ru this file ?, I’m a new linux user.
Thanks.
Hi Jules,
Daniel
Thanks Daniel
Jules ?
Hope that helps,
Daniel
Hi Jules,
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
dkastl
August 18, 2011, 8:56am
10
Hi Jules,
In your terminal window run
bash path/to/create_template.sh
Because I only used this on Ubuntu/Debian so far, you need to check if your OS lets you run commands as super user with “sudo”.
If you’re working as root user you can remove the “sudo” from the script.
If you get permission errors you may need to allow access in ph_hba.conf.
Daniel
On Thu, Aug 18, 2011 at 4:49 PM, Jules Kouadio <sekedoua@gmail.com > wrote:
Hi daniel.
Thanks.
Hi Jules,
Daniel
Thanks Daniel
Jules ?
Hope that helps,
Daniel
Hi Jules,
Daniel
Thanks
When i execute :
I get this error :
Permission denied
/usr/lib/libCGAL.a
/usr/lib/libCGAL.so
sudo ldconfig
or:
su
ldconfig
exit
-Steve W
Thanks .
