when i install pgrouting, i get this message on pgAdmin III:
Une erreur s'est produite :
ERREUR: n'a pas pu ouvrir le fichier de contrôle d'extension "c:/program
Files/PostgreSQL/9.2/share/extension/pgrouting.control" : Permission
denied.
I work on:
Windows Server 2003 R2
Entreprise x64 Edition
Service Pack 2.
PostgreSQL 9.2
Postgis 2.0
Pgrouting-pg92-binaries-2.0devw64.zip
I just tried installing on my
Windows 2003 R2 x 64-bit Standard Edition Service Pack 2
Runng: PostgreSQL 9.2.4, compiled by Visual C++ build 1600, 64-bit
Did an install on a database with postgis 2.1.0 beta2 as well as one
running postgis 2.0.1
And didn't run into any issue just using
CREATE EXTENSION pgrouting;
select * from pg_available_extensions where name = 'pgrouting';
Shows:
name | default_version | installed_version | comment
pgrouting | 2.0.0-dev | 2.0.0-dev | pgRouting Extension
That said - I accidentally disabled the packaging step on winnie so she had
a build as of 5/26 which I think had a script called
1.0.7.sql. I've just fixed this so she should now be packaging for each
run.
That said can you redownload and give the latest version a try. Only
difference I see between your windows setup and ming is you are running
Enterprise edition and I have standard. I suspect whatever issues are left
are permission related like if you did a move of the files instead of copy
it
Would get the rights of the folder you moved from rather than postgres
instance rights.
Regina
http://www.postgis.us
http://postgis.net
