Ross,
This might be just a windows packaging issue or you picked up an interim 2.0 when you installed.
I had this issue once, and I think the problem is you were maybe running 2.0 develop which shows as 2.0.0, but really isn’t 2.0.0. It’s somewhere between 2.0.0 and 2.1.0
You can tell because the actual released version have branch master or tag like this:
2.0.0;pgrouting-2.0.0;0;f26831f;master;1.53.0
Anyway you say you are testing with 9.3 32-bit. I’ll look into that to make sure I didn’t mispackage the 2.0.0 on the 9.3 32-bit.
If I didn’t then its just you installed the 2.0 package instead of the 2.0.0 package originally.
I don’t think any tables actually depend on pgRouting so if you don’t have any SQL functions built on it, it’s safe to just delete pgrouting extension and reinstall it.
Plpgsql are opaque anyway so the use of pgRouting in them will not force them to drop when you drop the pgRouting extension.
Regina
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of McDonaldR
Sent: Wednesday, August 12, 2015 5:24 AM
To: pgrouting-users@lists.osgeo.org
Subject: [pgrouting-users] Error updating to PgRouting 2.1.0 (Pg 9.3.9, 32bit)
Hello list,
I get an error message when trying to update pgRouting from 2.0.0 to 2.1.0 in a Postgresql 9.3.9 32bit database on Windows 7.
ALTER EXTENSION pgrouting UPDATE TO “2.1.0”;
ERROR: function pgr_alphashape(text) does not exist
SQL state: 42883
I am using this build of pgRouting - http://winnie.postgis.net/download/windows/pg93/buildbot/pgrouting-pg93-binaries-2.1.0-betaw32gcc481.zip
Currently installed version is:
“2.0.0”;“pgrouting-2.0.0”;“40”;“567ac3b”;“develop”;“1.53.0”
Was hoping to get:
2.1.0, pgrouting-2.1.0-alpha1, 81, 5fa89b2, develop_2_1_0, 1.58.0
For some context, the pgr_alphashape function currently installed in my database is:
– Function: public.pgr_alphashape(text, double precision)
– DROP FUNCTION public.pgr_alphashape(text, double precision);
CREATE OR REPLACE FUNCTION public.pgr_alphashape(IN sql text, IN alpha double precision DEFAULT 0, OUT x double precision, OUT y double precision)
RETURNS SETOF record AS
‘$libdir/librouting_dd’, ‘alphashape’
LANGUAGE c IMMUTABLE STRICT
COST 1
ROWS 1000;
The new alphashape function to be created looks like this:
CREATE OR REPLACE FUNCTION pgr_alphashape(sql text, alpha float8 DEFAULT 0, OUT x float8, OUT y float8)
AS ‘$libdir/librouting-2.1’, ‘alphashape’
LANGUAGE c IMMUTABLE STRICT;
Is it best to post these here or should I use Github issues?
Ross
Ross McDonald | GIS Data Coordinator | Resources Department, IT Division | Angus Council, Angus House, Orchardbank Business Park, Forfar, DD8 1AT
T: 01307 476419 | F: 01307 476401 | E: mcdonaldr@angus.gov.uk
This message is strictly confidential. If you have received this in error, please inform the sender and remove it from your system. If received in error you may not copy, print, forward or use it or any attachment in any way. This message is not capable of creating a legal contract or a binding representation and does not represent the views of Angus Council. Emails may be monitored for security and network management reasons. Messages containing inappropriate content may be intercepted. Angus Council does not accept any liability for any harm that may be caused to the recipient system or data on it by this message or any attachment.
