Hi everybody. After compiling pgrouting whith success, i begin my fist test whith the shortest_path() function. My data come from open street map. I’ve insert it in my database whith ./osm2pgrouting.
But a get an error when i execute this request:
SELECT * FROM shortest_path(‘SELECT gid as id,source::integer,target::integer,length::double precision as cost FROM ways’,965,14, false, false);
ERROR: Start vertex was not found.
Do you know where is the problem ?
Start vertex was not found … that’s the problem. You need to have “965” and “14” in “source” and “target”. Maybe you took the road link id (gid).
