Hi
Instead of shortest path I would like to use fastest path.
Can someone advice me about fastest path?
Asad
Hi
Asad
Hi Asad,
The fastest path is when your cost is the time to travel on a road segment.
You can take anything as cost.
Daniel
On Sun, Dec 4, 2011 at 10:14 PM, Asad Syed <asad_ip@yahoo.com> wrote:
Hi
Asad
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
The shortest path algorithm just chooses the minimum value stored in the “cost” column, put there the value you want to be minimized, i.e. you want the greatest speed put the negative speed in that column.
2011/12/4 Asad Syed <asad_ip@yahoo.com>
Hi
Asad
