I’m trying to install pgRouting on a cluster running CentOS-5. So far, the proj4 and geos have been compiled properly but the installation of postgis-1.3.3 produces the error messages that you can see attached.
As you said, you get this error when you install PostGIS, so it would be better to ask the PostGIS mailing list.
Do you have to use such an old release of PostGIS?
You could use the ELGIS repository, which provides PostGIS and pgRouting packages for CentOS 5: http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS
