I have a road network with appending a new segments sometimes.
Then I copy the new segments into my “road_noded” table and execute
SELECT pgr_createTopology(‘roads_noded’, 0.1, ‘geom’, ‘id’,rows_where:=‘id > a last id’)
for affecting on the new segments only. But this action recreates my “road_noded_vertices_pgr” table completely for the new segments instead of appending the new vertices and referencing them to the new segments.
Is pgr_createTopology only for create not for update? Somebody knows other method or some trick?
Could I use native Postgis functions (ST_StartPoint,ST_EndPoint etc) in the event if no possibility?
On Mon, Aug 25, 2014 at 11:00 AM, Vladimir <fl_v@inbox.ru> wrote:
Hi All
Then I copy the new segments into my "road_noded" table and execute
SELECT pgr_createTopology('roads_noded', 0.1, 'geom', 'id',rows_where:='id
> a last id')
"road_noded_vertices_pgr" table completely for the new segments instead of
1) Is pgr_createTopology only for create not for update? Somebody knows
Yes, this function does not do updates.
If you add or modify roads later, and if you don't want to keep old node
ID's, then you can't use this function.
2) Could I use native Postgis functions (ST_StartPoint,ST_EndPoint etc) in
I don't understand what you mean with "event", but yes, you can use any
PostGIS function to handle the updates. You could for example a trigger
function.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
