Starting a new project and I’d like to try to install pgrouting from the launchpad repository on Ubunut.
I have added the deb and deb-src lines to my sources list, but I’m not sure what to do from apt-get to install the package.
Thanks!
Steve Horn
Sorry, this is the launchpad repository I’m trying to add and install:
https://launchpad.net/~georepublic/+archive/pgrouting
Thanks!
Steve Horn
Steve Horn
dkastl
September 2, 2012, 11:57pm
3
Hi Steve,
If you’re not using a very ancient version of Ubuntu, it’s as easy as this:
sudo add-apt-repository ppa:georepublic/pgrouting
sudo apt-get update
sudo apt-get install postgresql-9.1-pgrouting
postgresql-9.1-pgrouting-dd
postgresql-9.1-pgrouting-tsp
(for Ubuntu 12.04 PostgreSQL is version 9.1, so the package name might be different for elder versions)
See also: http://workshop.pgrouting.org/chapters/installation.html#pgrouting
Daniel
Thanks!
Steve Horn
Steve Horn
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Wow, the workshop has been updated since I last saw it. Great install experience.
I’m doing some experimentation with the TSP code. Whenever I use the tsp function I get a seg fault in postgres without any other debugging information.
Is there something I should check first in this case?
On Sun, Sep 2, 2012 at 7:57 PM, Daniel Kastl <daniel@georepublic.de > wrote:
Hi Steve,
sudo apt-get update
Daniel
Thanks!
Steve Horn
Steve Horn
Steve Horn
