I am trying to import an osm file with osm2pgrouting, i have downloaded last version from git, and complied it from source. i am running (ubuntu 12.04, postgre 9.1, postgis 2.0)
After i run it, it build numerous tables, but it leaves the ways table empty.
Some googling yield mixed responses about this issue, and i saw some responses claiming its only working with postigs 1.5.
Is that the case?
If not, any suggestions how to check why does it not work?
On Thu, Dec 12, 2013 at 6:05 PM, Yaron Lev <yaron666@gmail.com> wrote:
empty.
Is that the case?
It should work with PostGIS 2.0.
At least it works on the recent OSGeo LiveDVD, which has PostGIS 2.0
