I wrote the legacy.sql more as an example to document how things changed, but it was never tested as we did not plan on supporting it. The idea behind it was to provide and an example to help people convert their existing applications to use the new functions.
Part of the problem with the legacy code is that it had not test suite and the code was very buggy. It also was haphazard because of its evolution and random things being added that people thought might be nice to have.
The best thing to do is use the new workshop and if you have questions or get stuck to ask the list and we will try to help you sort them out.
Regina.
It was from the foss4g 2007 workshop. The most recent worshops include
wrapper functions which I am not familiar with so I also get stuck at
some point.
What I am trying to do is to create a simple application that allows
users to set a start and end point and calculate the route using any one
of the major algorithms like the workshop describes.
So far, the user interface (based on openlayers 2.10) works well and
displays both points. I get an error in firebug when I click the
'calculate route' button and the php script is called, and this was
after I installed legacy.sql. I get "ERROR: type "geoms" does not exist"
when installing pgrouting.sql.
Here's the error from firebug:
|<br />
||<b>Warning</b>: pg_query(): Query failed: ERROR: parse error - invalid geometry
||HINT: "POINT( )" <-- parse error at position 9 within geometry in <b>C:\ms4w\Apache\htdocs||\hgt\routing.php</b> on line <b>42</b><br />
||<br />
||<b>Warning</b>: pg_fetch_result() expects parameter 1 to be resource, boolean given in <b>C:\ms4w\Apache||\htdocs\hgt\routing.php</b> on line <b>44</b><br />
||<br />
||<b>Warning</b>: pg_fetch_result() expects parameter 1 to be resource, boolean given in <b>C:\ms4w\Apache||\htdocs\hgt\routing.php</b> on line <b>45</b><br />
||<br />
||<b>Warning</b>: pg_fetch_result() expects parameter 1 to be resource, boolean given in <b>C:\ms4w\Apache||\htdocs\hgt\routing.php</b> on line <b>46</b><br />
||<br />
||<b>Warning</b>: pg_fetch_result() expects parameter 1 to be resource, boolean given in <b>C:\ms4w\Apache||\htdocs\hgt\routing.php</b> on line <b>47</b><br />
||<br />
||<br />
||<br />
||<br />
||<br />
||<br />
||<b>Warning</b>: pg_query(): Query failed: in <b>C:\ms4w\Apache\htdocs\hgt\routing.php</b> on line||<b>108</b><br />
||<br />
||<b>Warning</b>: pg_fetch_assoc() expects parameter 1 to be resource, boolean given in <b>C:\ms4w\Apache||\htdocs\hgt\routing.php</b> on line <b>115</b><br />
||<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
||<route>
||</route>|
And the html document:
<!DOCTYPE html>
<html>
<head>
<title>pgRouting Demo</title>
<link rel="stylesheet" href="openlayers/theme/default/style.css"
type="text/css">
<style>
#map-id {
width: 100%;
height: 512px;
border: 1px solid black;
</style>
<script src="openlayers/OpenLayers.js"></script>
</head>
<body>
<div id="map-id"></div>
<script>
var SinglePoint = OpenLayers.Class.create();
SinglePoint.prototype = OpenLayers.Class.inherit(OpenLayers.Handler.Point, {
createFeature: function(evt) {
this.control.layer.removeFeatures(this.control.layer.features);
OpenLayers.Handler.Point.prototype.createFeature.apply(this, arguments);
var start_style = OpenLayers.Util.applyDefaults({
externalGraphic: "start.png",
graphicWidth: 18,
graphicHeight: 26,
graphicYOffset: -26,
graphicOpacity: 1
}, OpenLayers.Feature.Vector.style['default']);
var stop_style = OpenLayers.Util.applyDefaults({
externalGraphic: "stop.png",
graphicWidth: 18,
graphicHeight: 26,
graphicOpacity: 1
var result_style = OpenLayers.Util.applyDefaults({
strokeWidth: 3,
strokeColor: "#ff0000",
fillOpacity: 0
// global variables
var map, parser, start, stop, result, controls;
var format = 'image/png';
var bounds = new OpenLayers.Bounds(
-0.178166372987693, 5.62323476776518,
-0.140817506885068, 5.64840001174401
var options = {
controls: ,
maxExtent: bounds,
maxResolution: 0.0001458940082134,
projection: "EPSG:4326",
units: 'degrees'
map = new OpenLayers.Map("map-id", options);
boundary = new OpenLayers.Layer.WMS(
"East Legon - Boundary",
"http://localhost:8080/geoserver/pgrouting/wms",
LAYERS: 'pgrouting:eastlegonboundary',
STYLES: '',
format: format,
tiled: true,
tilesOrigin : map.maxExtent.left + ',' +
map.maxExtent.bottom
buffer: 0,
displayOutsideMaxExtent: true,
isBaseLayer: true,
yx : {'EPSG:4326' : true}
eastlegon = new OpenLayers.Layer.WMS(
"East Legon",
LAYERS: 'pgrouting:eastlegon',
STYLES: '',
format: format,
transparent: true,
tiled: true,
buffer: 0,
isBaseLayer: false,
start = new OpenLayers.Layer.Vector("Start Point", {style: start_style});
stop = new OpenLayers.Layer.Vector("End Point", {style: stop_style});
result = new OpenLayers.Layer.Vector("Routing Results",
{style: result_style});
map.addLayers([boundary, eastlegon, start, stop, result]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.PanPanel());
map.addControl(new OpenLayers.Control.ZoomPanel());
map.addControl(new OpenLayers.Control.ScaleLine());
map.addControl(new OpenLayers.Control.Navigation());
map.addControl(new OpenLayers.Control.MousePosition());
map.zoomToExtent(bounds);
// controls
controls = {
start: new OpenLayers.Control.DrawFeature(start, SinglePoint),
stop: new OpenLayers.Control.DrawFeature(stop, SinglePoint)
for (var key in controls) {
map.addControl(controls[key]);
function toggleControl(element) {
for (key in controls) {
if (element.value == key && element.checked) {
controls[key].activate();
} else {
controls[key].deactivate();
function compute() {
var startPoint = start.features[0];
var stopPoint = stop.features[0];
if (startPoint && stopPoint) {
var result = {
startpoint: startPoint.geometry.x + ' ' +
startPoint.geometry.y,
finalpoint: stopPoint.geometry.x + ' ' +
stopPoint.geometry.y,
method: OpenLayers.Util.getElement('method').value,
region: "eastlegon",
srid: "4326"
OpenLayers.loadURL("./routing.php",
OpenLayers.Util.getParameterString(result),
null,
displayRoute);
function displayRoute(response) {
if (response && response.responseXML) {
// erase the previous results
result.removeFeatures(result.features);
// parse the features
var edges =
response.responseXML.getElementsByTagName('edge');
var features = ;
for (var i = 0; i < edges.length; i++) {
var g =
parser.read(edges[i].getElementsByTagName('wkt')[0].textContent);
features.push(new OpenLayers.Feature.Vector(g));
result.addFeatures(features);
</script>
<ul>
<li>
<input type="radio" name="control" id="noneToggle"
onclick="toggleControl(this);" checked="checked" />
<label for="noneToggle">navigate</label>
</li>
<li>
<input type="radio" name="control" value="start" id="startToggle"
onclick="toggleControl(this);" />
<label for="startToggle">set start point</label>
</li>
<li>
<input type="radio" name="control" value="stop" id="stopToggle"
<label for="stopToggle">set stop point</label>
</li>
</ul>
<select id="method">
<option value="SPD">Shortest Path Dijkstra - undirected (BBox)</option>
<option value="SPA">Shortest Path A Star - undirected</option>
<option value="SPS">Shortest Path Shooting Star</option>
</select>
<button onclick="compute()">Calculate Route</button>
</body>
</html>
On Jan 4, 2014 3:45 AM, "Paragon Corporation" <lr@pcorp.us
<mailto:lr@pcorp.us>> wrote:
__
Emmanuel,
That PHP code looks like it was written for pgRouting 1.0. Which
workshop did you get that from?
Most of the pgRouting 2.0 functions are prefixed with pgr_. There
should be a file in your install called
In C:/Program
Files/PostgreSQL/9.2/share/extensions/pgrouting_legacy.sql which
installs the 1.0 function names. You could try using that though I
haven't personally had a need to.
One other thing I did notice about this code which I think is a bug
is that although PG_PORT is defined, it doesn't seem to be used for
pg_connect, so will not work without modification if you are
runnning postgres on non-default port (5432).
Hope that helps,
Regina
http://www.postgis.us
http://www.bostongis.com
http://www.paragoncorporation.com
<mailto:pgrouting-users-bounces@lists.osgeo.org>
[mailto:pgrouting-users-bounces@lists.osgeo.org
<mailto:pgrouting-users-bounces@lists.osgeo.org>] *On Behalf Of
*Emmanuel Adegboye
*Sent:* Friday, January 03, 2014 4:42 PM
*To:* pgrouting-users@lists.osgeo.org
<mailto:pgrouting-users@lists.osgeo.org>
*Subject:* [pgrouting-users] Issues with pgrouting workshop code in
postgis2.11/pgrouting 2.0
I'm having issues getting the pgrouting workshop to work on
Postgresql 9.2/PostGIS 2.11 and pgrouting 2.0 on windows.
How can I rewrite the following php/sql code and make it compatible
with my version:
|<?php
// Database connection settings
define("PG_DB" , "routing");
define("PG_HOST", "localhost");
define("PG_USER", "postgres");
define("PG_PORT", "5432");
define("PG_PASSWD", "*******");
define("TABLE", "eastlegon");
$counter= $pathlength= 0;
// Retrieve start point
$start= split('',$_REQUEST['startpoint']);
$startPoint= array($start[0], $start[1]);
// Retrieve end point
$end= split('',$_REQUEST['finalpoint']);
$endPoint= array($end[0], $end[1]);
// Find the nearest edge
$startEdge= findNearestEdge($startPoint);
$endEdge= findNearestEdge($endPoint);
// FUNCTION findNearestEdge
function findNearestEdge($lonlat) {
// Connect to database
$con= pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER." password=".PG_PASSWD);
$sql= "SELECT gid, source, target, the_geom,
distance(the_geom, GeometryFromText(
'POINT(".$lonlat[0]."".$lonlat[1].")', 4326)) AS dist
FROM ".TABLE."
WHERE the_geom && setsrid(
'BOX3D(".($lonlat[0]-200)."
".($lonlat[1]-200).",
".($lonlat[0]+200)."
".($lonlat[1]+200).")'::box3d, 4326)
ORDER BY dist LIMIT 1";
$query= pg_query($con,$sql);
$edge['gid'] = pg_fetch_result($query, 0, 0);
$edge['source'] = pg_fetch_result($query, 0, 1);
$edge['target'] = pg_fetch_result($query, 0, 2);
$edge['the_geom'] = pg_fetch_result($query, 0, 3);
// Close database connection
pg_close($con);
return $edge;
// Select the routing algorithm
switch($_REQUEST['method']) {
case 'SPD' : // Shortest Path Dijkstra
$sql= "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
length(rt.the_geom) AS length, ".TABLE.".id
FROM ".TABLE.",
(SELECT gid, the_geom
FROM dijkstra_sp_delta(
'".TABLE."',
".$startEdge['source'].",
".$endEdge['target'].",
3000)
) as rt
WHERE ".TABLE.".gid=rt.gid;";
break;
case 'SPA' : // Shortest Path A*
FROM ".TABLE.",
FROM astar_sp_delta(
'".TABLE."',
3000)
) as rt
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org <mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
