Hi Emmanuel
If you want to make the old workshop works on pgRouting 2.0
Here you have to change the function to pgRouting 2.0 using pgr_dijkstra function as show below;
case ‘SPD’ : // Shortest Path Dijkstra
$sql = “SELECT w.gid, AsText(w.the_geom) AS wkt,w.name, ST_length(w.the_geom) AS length, w.gid FROM “.TABLE.” w,
(SELECT seq, id1 AS node, id2 AS edge,cost FROM pgr_dijkstra(’
SELECT gid AS id,source::integer,
target::integer,
length::double precision AS cost
FROM “.TABLE.”',
“.$startEdge[‘source’].”,
“.$endEdge[‘target’].”, false, false) )as rt where w.gid=rt.edge;”;
break;
Bomp
Graduate School for Creative Cities
Urban Informatics
GIS Laboratory
Osaka City University 大阪市立大学
Sittichai Choosumrong
TEL +81-80-3812-2102
|<?php
// Database connection settings
define(“PG_DB” , “routing”);
define(“PG_HOST”, “localhost”);
define(“PG_USER”, “postgres”);
define(“PG_PORT”, “5432”);
define(“PG_PASSWD”, “*******”);
define(“TABLE”, “eastlegon”);$counter= $pathlength= 0;
// Retrieve start point
$start= split(‘’,$_REQUEST[‘startpoint’]);$startPoint= array($start[0], $start[1]);
// Retrieve end point
$end= split(‘’,$_REQUEST[‘finalpoint’]);$endPoint= array($end[0], $end[1]);
// Find the nearest edge
$startEdge= findNearestEdge($startPoint);$endEdge= findNearestEdge($endPoint);
// FUNCTION findNearestEdge
function findNearestEdge($lonlat) {// Connect to database
$con= pg_connect(“dbname=”.PG_DB." host=“.PG_HOST.” user=“.PG_USER.” password=".PG_PASSWD);
$sql= "SELECT gid, source, target, the_geom,
distance(the_geom, GeometryFromText(
‘POINT(“.$lonlat[0].”“.$lonlat[1].”)’, 4326)) AS dist
FROM “.TABLE.”
WHERE the_geom && setsrid(
‘BOX3D(“.($lonlat[0]-200).”
“.($lonlat[1]-200).”,
“.($lonlat[0]+200).”
“.($lonlat[1]+200).”)’::box3d, 4326)
ORDER BY dist LIMIT 1";$query= pg_query($con,$sql);
$edge[‘gid’] = pg_fetch_result($query, 0, 0);
$edge[‘source’] = pg_fetch_result($query, 0, 1);
$edge[‘target’] = pg_fetch_result($query, 0, 2);
$edge[‘the_geom’] = pg_fetch_result($query, 0, 3);// Close database connection
pg_close($con);return $edge;
}// Select the routing algorithm
switch($_REQUEST[‘method’]) {case ‘SPD’ : // Shortest Path Dijkstra
$sql= “SELECT rt.gid, AsText(rt.the_geom) AS wkt,
length(rt.the_geom) AS length, “.TABLE.”.id
FROM “.TABLE.”,
(SELECT gid, the_geom
FROM dijkstra_sp_delta(
'”.TABLE.“',
3000)
) as rt
WHERE “.TABLE.”.gid=rt.gid;”;
break;
It is works on my Computer using this code.
Best,
