I have compiled pgrouting from the github version against Postgres 9.2, and when I try to do a psql -d routing -f routing_core.sql, I get the following:
psql:routing_core.sql:32: ERROR: language “C” does not exist
psql:routing_core.sql:43: ERROR: language “C” does not exist
psql:routing_core.sql:53: ERROR: language “C” does not exist
I thought C was built in to Postgres, as when I do a createlang, postgres says it is already built in.
Changing LANGUAGE 'C' to LANGUAGE 'c' did the trick.
With dd I am getting the gmpq_equal error that comes up. I know there is a solution to this but I am not on the internet now so I can not go and look for it.
Quick help on this one please. Built against cgal 3.9. Ubuntu install except for gaul which was built from source.
Pieter
Sent from my BlackBerry® wireless device
-----Original Message-----
Sender: pgrouting-users-bounces@lists.osgeo.org
Date: Fri, 14 Sep 2012 05:32:58
To: pgRouting users mailing list<pgrouting-users@lists.osgeo.org>
Reply-To: pgRouting users mailing list <pgrouting-users@lists.osgeo.org>
Subject: Re: [pgrouting-users] Language "C" not found
Changing LANGUAGE ‘C’ to LANGUAGE ‘c’ did the trick.
