[ 0%] Built target ProcessSQLFiles
[ 0%] Built target build-time-sql-directory
[ 1%] Building C object src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o
In file included from /usr/include/pgsql/server/c.h:53:0,
from /usr/include/pgsql/server/postgres.h:47,
from /root/pgrouting-2.4.0/src/withPoints/src/./…/…/common/src/postgres_connection.h:34,
from /root/pgrouting-2.4.0/src/withPoints/src/one_to_one_withPoints.c:30:
/usr/include/pgsql/server/pg_config.h:14:30: fatal error: pg_config_x86_64.h: No such file or directory #include “pg_config_x86_64.h”
compilation terminated.
make[2]: *** [src/withPoints/src/CMakeFiles/withPoints.dir/one_to_one_withPoints.c.o] Error 1
make[1]: *** [src/withPoints/src/CMakeFiles/withPoints.dir/all] Error 2
make: *** [all] Error 2
In particular you may be missing the postgresql-server-dev-xx package as it’s named in Debian/Ubuntu.
Looking at your error output it seems like you try to compile pgRouting 2.4.
There are already much newer versions in the meanwhile, so you may better try those.
I can’t say much about Redhat/CentOS, but I thought there should also be packages available on those platforms.
On Debian/Ubuntu you can add the PostgreSQL maintained repositories and always have access to the latest versions.
I haven’t tried, but this might be also the case for CentOS: https://www.postgresql.org/download/
