Hello Danniel. Thanks again for your support. I progress but i have so much to learn.
why this error for this 3 request ?
SELECT * from driving_distance(‘select gid as id,source,target,length::double precision as cost from ways’,22777838,0.01);
ERROR: function driving_distance (“unknown”, integer, numeric) does not exist
HINT: No function matches the given name and argument types. You need to add explicit type conversions.
SELECT * FROM shortest_path_astar(‘select gid as id,source::int4,target::int4,reverse_cost::double precision as reverse_cost,x1,y1,x2,y2 from ways’,22,150,false,false);
ERREUR: Error, query must return columns ‘id’, ‘source’, ‘target’ and ‘cost’
SELECT * from tsp(‘select distinct source as source_id,x1::double precision as x,y1::double precision as y from ways where source in(91,35,75,504,254)’,‘91,35,75,504,254’,353);
WARNING: stop the connection because of crash of another server process
DETAIL: The postmaster has commanded this server process to cancel the transaction
Current and leave because another process server left abnormally
and there is probably corrupted shared memory.
TIP: In a moment you should be able to reconnect to the base of
data and restart your order.
the server connection was cut off unexpectedly
The server may have terminated abnormally before or during
processing the request.
The server connection was lost. Attempting reset: success / or sometimes not.
I don’t understand why all thes errors becose shortest_path function run correctly. Exple
SELECT * FROM shortest_path(‘SELECT gid as id,source::integer,target::integer,length::double precision as cost FROM ways’,300,400, false, false); give to me :
vertex_id | edge_id | cost
300 | 339 | 0.139255214687805
299 | 338 | 0.179544765048058
195 | 337 | 0.203993410356029
63 | 56 | 0.163071365291157
64 | 57 | 0.0210195901922476
13 | 592 | 0.154135925931186
353 | 593 | 0.167432867084967
255 | 594 | 0.0922310799956524
111 | 595 | 0.410249680272814
435 | 596 | 0.323252439058039
400 | -1 | 0
(11 lignes)
My table “ways” is join.
Thanks !
dump.sql (368 KB)
