[pgrouting-users] osm_relations table does not get populated
Problem
When running osm2pgrouting on a typical .osm file with the --addnodes option, osm_relations table stays empty.
To Reproduce
osm2pgrouting -f home/map.osm -c "/usr/local/share/osm2pgrouting/mapconfig.xml" -d city_routing -U [username] -W [password] --clean --tags --addnodes
Expectation
I use the --addnodes flag as per the documentation and I can see that osm_nodes and osm_ways tables do get populated. However, osm_relations has 0 records after running osm2pgrouting and “Final osm_relations:” is never mentioned in the output:
Creating tables...
TABLE: ways_vertices_pgr created ... OK.
TABLE: ways created ... OK.
TABLE: pointsofinterest created ... OK.
TABLE: configuration created ... OK.
TABLE: osm_nodes created ... OK.
TABLE: osm_ways created ... OK.
TABLE: osm_relations created ... OK.
Opening configuration file: /usr/local/share/osm2pgrouting/mapconfig.xml
    Parsing configuration
Exporting configuration ...
  - Done
Counting lines ...
  - Done
Opening data file: home/map.osm  total lines: 175957
    Parsing data
Current osm_nodes:      48000
Final osm_nodes:        48375
Current osm_ways:       6000
Final osm_ways:         6320
End Of file
    Finish Parsing data
Adding auxiliary tables to database...
Export Ways ...
Creating indexes ...
Processing Points of Interest ...
Adding functions for processing Points of Interest ...
To process pointsOfInterest table:
osm2pgr_pois_update(radius default 200, within default 50)
  - Using areas of (radius)mts on POIS
  - Using edges that are at least (within) mts of each POI
POIS that do not have a closest edge is considered as too far
size of streets: 6320
Execution started at: Tue May 30 10:07:09 2023
Execution ended at:   Tue May 30 10:07:21 2023
Elapsed time: 11.767 Seconds.
User CPU time: -> 1.12268 seconds
Sample Data
A sample .osm file is attached (please rename from txt to osm if needed), however I have tried other .osm exports that contain osm relations with the same result.
haywards-heath-uk-small-extract.txt
Platform/versions
SELECT version();
PostgreSQL 15.3 (Debian 15.3-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
SELECT postgis_full_version();
POSTGIS="3.3.2 4975da8" [EXTENSION] PGSQL="150" GEOS="3.9.0-CAPI-1.16.2" PROJ="7.2.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
SELECT pgr_version();
3.4.1
haywards-heath-uk-small-extract.osm (1.13 MB)
Hello,
I can not reproduce your problem:
What is needed:
  1. The exact data that has been used, can be in the form of a link to a shared file, the wget command to download from osm.
  2. the exact command that is been used (use mylogin and mypass instead of the real ones when posting the command)
Regards
Vicky
On Fri, Jun 2, 2023 at 3:52 AM Tokura Gou <tokura.gou@gmail.com> wrote:
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Hello Vicky and thanks for your response,
Maybe due to formatting issues the data and the command were not visible.
  1. Data: https://github.com/pgRouting/osm2pgrouting/files/11598959/haywards-heath-uk-small-extract.txt
  2. Exact command: osm2pgrouting -f home/map.osm -c “/usr/local/share/osm2pgrouting/mapconfig.xml” -d city_routing -U [username] -W [password] --clean --tags --addnodes
On Fri, Jun 2, 2023 at 6:25 PM Vicky Vergara <vicky@erosion.dev> wrote:
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
Hello,
In the data file you’ve provided, named ‘haywards-heath-uk-small-extract.txt’,
there are 8 OpenStreetMap (OSM) relation objects [2]
that are marked as either ‘boundary=*’ or ‘landuse=residential’.
It appears that none of these are related to routes or are included in the ‘mapconfig.xml’ [1] file.
Could you please specify which OSM relation you’re missing from your table?
Could you also test it with another input data set? Specifically, one that includes a ‘highway=*’ osm relation in the extract.
[1] https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig.xml
[2] osmium cat haywards-heath-uk-small-extract.osm.xml -t relation -f opl | cut -d’ ’ -f8
[3] https://taginfo.openstreetmap.org/keys/highway#overview
Imre
Tokura Gou <tokura.gou@gmail.com> ezt írta (időpont: 2023. jún. 3., Szo, 19:11):
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
Hello Imre,
Thanks for your comment.
I will test with another data set.
Meanwhile, may I ask:
  1. It seems that by default osm2pgrouting will only store those osm_relations that are related to routes and that contain “highway”-tagged ways, is this correct?
  2. Is it possible to edit mapconfig.xml to include other, non-highway relations?
Thank you.
On Sun, Jun 4, 2023 at 4:21 PM Imre Samu <pella.samu@gmail.com> wrote:
Hello,
Imre
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
Another input dataset:
Attaching another .osm extract (please rename from .txt). This file contains at least one highway (“Sydney Road”) which is a part of a route relation (“270 Brighton - East Grinstead”).
This highway has a tag highway=secondary which is declared in mapconfig.xml.
On Mon, Jun 5, 2023 at 11:17 AM Tokura Gou <tokura.gou@gmail.com> wrote:
Hello Imre,
Thank you.
Hello,
Imre
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
haywards-heath-uk-small-extract-routes.osm.txt (615 KB)
In my opinion, yes. (But please note that I’m just a user.)
  1. Is it possible to edit mapconfig.xml to include other, non-highway relations?
check the https://github.com/pgRouting/osm2pgrouting/blob/main/mapconfig_for_bicycles.xml
  • cycleway
  • cycleway:right
  • cycleway:left
  • tracktype
  • highway
If you want to include non-route related data, such as Points of Interest (POIs), borders, and so on, I recommend using https://osm2pgsql.org/.
This tool can also be a useful way to verify the functioning of the osm2pgrouting program.
If you’re finding that a route is present in the osm2pgsql tables but not in the osm2pgrouting ones, it’s likely that you need to adjust the configuration.
There can be a wide variety of ‘highway=’ values, as OSM editors can use any key-value pair.
You can see a list of these values at https://taginfo.openstreetmap.org/keys/highway#values.
Sometimes, an extract might not contain all parts of an extremely long relation, which means it won’t be imported.
In such cases, osm2pgsql also won’t import it. This situation can help you identify potential data issues.
Be aware that there’s a known issue with osm2pgrouting ;
If you’re using it, consider increasing the value of the “–chunk” parameter. ( --chunk 10000000 )
https://github.com/pgRouting/osm2pgrouting/issues/296
Imre
Tokura Gou <tokura.gou@gmail.com> ezt írta (időpont: 2023. jún. 5., H, 11:20):
Hello Imre,
Thank you.
Hello,
Imre
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
You can use “osmium check-refs” to check referential integrity of OSM file.
https://docs.osmcode.org/osmium/latest/osmium-check-refs.html
osmium check-refs -r haywards-heath-uk-small-extract-routes.osm.xml
[======================================================================] 100%
There are 1969 nodes, 197 ways, and 14 relations in this file.
Nodes in ways missing: 0
Nodes in relations missing: 297 <---- !!!
Ways in relations missing: 870 <---- !!!
Relations in relations missing: 0
( adding: “-i, --show-ids” ) you can check the missing ids.
osmium check-refs -i -r haywards-heath-uk-small-extract-routes.osm.xml
missing ways in https://www.openstreetmap.org/relation/11566101
w20863252 in r11566101
w1124142166 in r11566101
w1124142167 in r11566101
w159596938 in r11566101
w181594063 in r11566101
missing ways in https://www.openstreetmap.org/relation/11566102
w14396123 in r11566102
w153899205 in r11566102
w223616400 in r11566102
w145426967 in r11566102
And you can check your example: “270 Brighton → East Grinstead”
https://www.openstreetmap.org/relation/11561226
osmium check-refs -i -r haywards-heath-uk-small-extract-routes.osm.xml | grep r11561226
w960935109 in r11561226
w954035172 in r11561226
w954241918 in r11561226
w3807763 in r11561226
w843923122 in r11561226
w964331211 in r11561226
w986987784 in r11561226
w3995557 in r11561226
w986987785 in r11561226
w165441577 in r11561226
w4378508 in r11561226
w137403281 in r11561226
w137403098 in r11561226
w638278559 in r11561226
w719574502 in r11561226
w793744330 in r11561226
imho :
if you are using osmium extract [2] probably you have to use the “Strategy: smart” to extract osm data.
"When using the smart strategy, everything is done as in the complete_ways strategy, but multipolygon relations that have at least one node in the region will also be completely included. You can see this in the example image: If a multipolygon relation ties the red, green, and blue ways together, the blue way and all its nodes will be included.
…**" [1]
[1] https://osmcode.org/osmium-tool/manual.html#creating-geographic-extracts
[2] https://docs.osmcode.org/osmium/latest/osmium-extract.html
Imre
Tokura Gou <tokura.gou@gmail.com> ezt írta (időpont: 2023. jún. 5., H, 12:11):
Hello Imre,
Thank you.
Hello,
Imre
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
Hi Tokura San:
Yes it is possible, you have to make your own.
There is are 2 examples here:
https://workshop.pgrouting.org/2.8/en/un_sdg/data.html#appendix
One is incorporating buildings the other one incorporates waterways
Regards
Vicky
  • cycleway
  • cycleway:right
  • cycleway:left
  • tracktype
  • highway
Imre
Hello Imre,
Thank you.
Hello,
Imre
Hello,
What is needed:
Regards
Vicky
Problem
To Reproduce
Expectation
Creating tables...
  - Done
Counting lines ...
  - Done
    Parsing data
End Of file
    Finish Parsing data
Export Ways ...
Sample Data
Platform/versions
SELECT version();
3.4.1
