Vicky has released osm2pgrouting 2.1.0 Beta.
You can read about it and download from here:
https://github.com/pgRouting/osm2pgrouting/releases/tag/osm2pgrouting-2.1.0-beta
The release starts refactoring the osm2pgrouting code. There are a lot of bug fixes and enhancements in this code. The link above also links to the issues that were closed.
WE NEED YOUR HELP! Things that you can do:
* please check any issues you reported against prior releases
* download, compile, and try it out and report any issues that you find
* Mac OS-X testing. This is important for someone to compile, install and make some simple tests. Our normal OS-X guru is busy and it would be great to get some confirmation that this is working.
Please give us a helping hand with getting this release tested and out the door.
Best regards,
-Steve
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
20 March 2016 13:42, "Stephen Woodbridge" <woodbri@swoodbridge.com> wrote:
Hi
Is there some sort test suit that can be run ?
I could build it on my local machine, but other than ensuring that it compiles that is not a very good way of testing things.
Dave.
Best regards,
-Steve
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Hi
Tried building this on Ubuntu 15.10 using g++ version 4.5.2.1 vers postgres 9.5
See the attached list of errors when building it
Dave.
Best regards,
-Steve
out (6.39 KB)
Hi
It seems that there is an error in osm2pgrouting.cpp
You need to add #include <iostream> otherwise it gets confused about cout being a memeber of std
e.g.
#include <unistd.h>
#include <string>
#include <iostream>
#include <ctime>
#include <chrono>
#include "./ConfigurationParserCallback.h"
#include "./OSMDocument.h"
#include "./OSMDocumentParserCallback.h"
#include "./Export2DB.h"
#include "./prog_options.h"
I made this change on my machine and it build
Dave
20 March 2016 17:14, dave.potts@pinan.co.uk wrote:
Hi
Dave.
Best regards,
-Steve
Hi Dave,
Vicky put together a doc file with some examples in it. Does this help?
https://github.com/pgRouting/osm2pgrouting/wiki/V2.1-documentation
-Steve
Hi
Dave.
Best regards,
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Vicky has created a new doc page for osm2pgrouting here:
and linked it to the release notes. This should help with getting you started.
-Steve
On 3/20/2016 9:39 AM, Stephen Woodbridge wrote:
the door.
Best regards,
-Steve
