I imported Virginia using osm2pgrouting and all is good, but i realized that the shortest path for 2 given points may rely on going through DC and Maryland. What's the workflow for importing multiple data sets? Should osm2pgrouting be used or to it be done from scratch?
thanks,
Brian
Brian DeRocher
http://brian.derocher.org
http://mappingdc.org
http://about.me/brian.derocher
Hi Brian,
osm2pgrouting is not able to connect separate imports.
But if you imported multiple times, it might work to run pgr_createTopology function again, so it will reassign source and target ID’s.
Daniel
On Wed, Jun 4, 2014 at 5:44 AM, Brian DeRocher <brian@derocher.org> wrote:
I imported Virginia using osm2pgrouting and all is good, but i realized that the shortest path for 2 given points may rely on going through DC and Maryland. What’s the workflow for importing multiple data sets? Should osm2pgrouting be used or to it be done from scratch?
thanks,
Brian
Brian DeRocher
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
