hi,
I have a question regarding the mapconfig.xml files. I’ve imported Austrian streets by issuing the command:
osm2pgrouting -f austria-latest.osm -h localhost -U postgres -d catchment -W postgres --conf=/usr/share/osm2pgrouting/mapconfig_for_cars.xml
In case I want to compute pedestrian catchment areas, is it okay to pass false as the last parameter to the pgr_drivingdistance?
Currently, the usage looks like this:
pgr_drivingdistance(‘SELECT gid AS id, source, target, length_m / 1.3 AS cost FROM public.ways’,
pgr_pointToEdgeNode(‘public.ways’, ST_Point($1, $2), 0.01),
limit_max,
false)
- SELECT gid AS id, source, target, length_m / 1.3 AS cost FROM public.ways
costs are minutes (length_m / pedestrian’s speed = seconds)
limit_max is a seconds value such as 900 (=15 minutes)
false is the last parameter of pgr_drivingdistance (= undirected graph)
Do I need to re-import the data to get a truly pedestrian suitable network?
Thank you in advance.
Katarina
