For any of you that might be using my osrm-tools package at https://github.com/woodbri/osrm-tools
I have pushed a bunch of changes over the last few days fixing issues that users have reported in pgr2osrm and added some new functions to the postgresql package.
I strongly recommend that you upgrade to the current master branch and extract your data again.
-Steve
Thanks Steve!
Going to check in the next few days and report back.
Helder Alves
On Jan 28, 2014 4:35 PM, “Stephen Woodbridge” <woodbri@swoodbridge.com> wrote:
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Hi Steve,
How are you doing?
Have you had any luck improving osrm-tools to generate valid TSP dmatrices usable on pgRouting?
Helder Alves
-Steve
On 2/22/2014 9:21 PM, Helder Alves wrote:
Hi Steve,
How are you doing?
Prety good. I have been very busy lately so osrm-tools and pgrouting work is suffering a little. But better to be busy than not
Yes, this works very well. I have been able to generate 30x30 distance matrix using a local OSRM instance by calling it from postgresql and it only takes a few seconds.
I had some demos running but they are currently down as I had osrm-routed setup to debug a problem that turned out to be bad data and not software.
I need to re-sync the pgr2osrm tools to the current Project-OSRM master as there have been some code changes. But it would fine for the using the checkout that Ihave documented.
Best regards,
-Steve
Helder Alves
On Jan 28, 2014 4:35 PM, "Stephen Woodbridge" <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>> wrote:
https://github.com/woodbri/__osrm-tools
<https://github.com/woodbri/osrm-tools>
-Steve
_________________________________________________
Pgrouting-users@lists.osgeo.__org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Thanks for the update, Steve.
I’ll be waiting for the code re-sync…
Helder Alves
On Sun, Feb 23, 2014 at 7:11 AM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hi Steve,
How are you doing?
Best regards,
-Steve
Helder Alves
mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)> wrote:
-Steve
mailto:[Pgrouting-users@lists.osgeo.org](mailto:Pgrouting-users@lists.osgeo.org)
