[pgrouting-users] pass query results to routing function
I’m wondering if anyone has an example of a query that calculates routes between pairs of nodes that is a subset of all the possible pairs in the network.
I have a network with ~5297 nodes, for ~28 million possible pairs. I could calculate routes for all of these pairs and then use the subset of routes that i need, but it seems that there could be a way to calculate only routes for the ~17 thousand pairs I actually care about. If possible I would filter to only calculate pairs where the origin node is ST_DWITHIN(a.geom, b.geom, 250), for example.
is there a way to pass the results of a query to the pgr_dijkstra() function? I haven’t seen an example of that as I’ve read through the docs. is there a way to apply a condition like st_diwthin() to the arrays passed to the function?
thanks for any advice or suggestions, hope everyone’s week is off to a good start.
Hugh
To follow up, the structure below seems to work fairly well for this. would still be curious to see better options if anyone knows of any.
This is a little awkward since it ends up returning a results table that’s a single column that’s a pseudo type record.
drop table if exists scratch.routing_pairs;
create table scratch.routing_pairs as (
select
dp1.tdg_id as origin_id,
dp1.nearest_net_node as origin_node,
dp2.tdg_id as dest_id,
dp2.nearest_net_node as dest_node
from
automated.doors_and_parking dp1
left join automated.doors_and_parking dp2 on st_dwithin(dp1.geom, dp2.geom, 250)
limit
100
select
pgr_dijkstra(
‘SELECT tdg_id as id, source, target, length_cost as cost FROM automated.ped_network as edge_table where source is not null and target is not null’,
origin_node,
dest_node,
false
from
Hugh Kelley
Hi Hugh,
… query that calculates routes between pairs of nodes that is a subset of all the possible pairs in the network.
Have you tried the “combinations SQL” method?
https://docs.pgrouting.org/latest/en/pgr_dijkstra.html#combinations
SELECT * FROM pgr_dijkstra(
‘SELECT id, source, target, cost, reverse_cost FROM edge_table’,
‘SELECT * FROM combinations_table’,
FALSE
Imre
Hugh Kelley <hghklly@gmail.com> ezt írta (időpont: 2022. máj. 9., H, 21:43):
select
from
limit
100
select
pgr_dijkstra(
origin_node,
dest_node,
false
from
On Mon, May 9, 2022 at 3:22 PM Hugh Kelley <hghklly@gmail.com> wrote:
Hugh
Hugh Kelley
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
thanks Imre, I had looked at that but hadn’t seen this query in the examples showing how it’s meant to be structured. That’s exactly what I needed.
    'SELECT id, source, target, cost, reverse_cost FROM edge_table',
    'SELECT * FROM (VALUES (2, 3), (2, 5), (11, 3), (11, 5)) AS combinations (source, target)'
Hugh Kelley
