Hi All,
Another big change just got pushed to the repository for sew-devel-2_0.
This change involved refactoring and abstracting our return types from our functions. Basically every function was create a new return type that was the same but a little different mostly in the column names.
So what we now have are:
CREATE TYPE pgr_costResult AS
seq integer,
id1 integer,
id2 integer,
cost float8
CREATE TYPE pgr_geomResult AS
seq integer,
id1 integer,
id2 integer,
geom geometry
CREATE TYPE pgr_vertexResult AS
x float8,
y float8
and I have eliminated 6 of the old types, namely:
pgr_pathResult
pgr_geoms
pgr_apspEdge
pgr_linkPoint
pgr_kspResult
pgr_kspGeoms
You will also notice that I have added a seq column to the first two types and this can be used to maintain order if you need two.
So what are id1 and id2? these are just generic names, you will have to looks at the specify function to see what it returns in these slots.
The docs have NOT been updated to reflect these changes, but Daniel and I will work on this over the next few days.
CALL FOR HELP!
One of the things that we really could use some help with is building test cases. I would like to see a minimum of one test per function call and ideally one for each of the variation that a function has.
This should not be that hard to do, because we have cut down significantly on the number of functions by abandoning most of the wrapper functions. But there are still a lot of functions in the src/common/sql/ directory that have no test. When I was converting the code for the changes above, I found a bunch functions in the matching code that clearly have never worked correctly because they had assignments like:
variable = equation;
which basic computes the boolean comparison of variable and equation and then throws away the result. Oooops! This must be written like:
variable := equation;
to do an assignment.
Anyway having the tests that we do have made it much faster to identify problems in the code I changed and to make sure everything was working as it was before I made the changes. I'm just worried about the things we do not have test for! and should should you!
Let me know how it goes when you have a chance to give it a try.
-Steve
