Hi List
I am playing around with pgr_analyzegraph, its told me I have
Dead ends: 7
Potential gaps found near dead ends: 3
In a network of 7000 vertexs finding Potential gaps in a map that I did not generate is going to be hard, is there anyway of get pgroute to actually tell me were these problems are?
Those are geometry gaps, so maybe you can ask on postGIS
On Sun, May 20, 2018 at 12:16 PM, Dave Potts <mrdapotts@gmail.com> wrote:
Hi List
Dead ends: 7
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
I assume you mean something like a multi line string with a hole in it !
Hi List
Dead ends: 7
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
What I mean is that maybe you have like the example on the docuemntation
1, 2, 1, 1, 130, 100, 0.5, 3.5, 1.999999999999,3.5),
the
1.999999999999
is almost 2, but its not a 2, so if another segment start on (2, 3.5) then
unless if you don’t use a tolerance to assign source and target values both vertices will have a different id
if you assign a tolerance then both vertices will have the same id, but note that for one id there would be two different values on the geometry, if you also want to “fix” the geometry then that is done with PostGIS
Hi List
Dead ends: 7
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
