Helder,
On 1/6/2014 12:11 AM, Helder Alves wrote:
I was able to make pgr_apspjohnson work but came to the conclusion that
when we have available a valid distance matrix suitable for TSP/VRP it
makes no sense to feed anything else to pgr_tsp or pgr_vpronedepot as
the results will be suboptimal.
Regarding pgr_vrponedepot I was able to also make it work however I
guess I stumbled on several issues:
* Depot open/close time seems to not be obeyed;
* Traveltime also seems to not being considered between departure and
arrival time every time;
One thing that may not be obvious is that times in pgr_vrponedepot are all zero based on the depot open time. So depot open time should always be zero and then are other time should be time units in the future from the open time.
* After each query I have to restart PostgreSQL as last query result
seems to be stuck "somewhere" (memory?) and all subsequent queries
return the very same result;
you might need to change the pgr_vrponedepot sql wrapper to volatile if it is not.
pgrouting/src/vrp_basic/sql/routing_vrp.sql
should say:
LANGUAGE c VOLATILE STRICT;
* When I have to cancel some running query, cancelling procedure takes
forever and the only way I found to stop it is by killing postgresql
process.
Once it get into the C/C++ code we do not get the cancel request. I'll have to do some research and see if there is a function call we can check for a pending CancelRequest.
-Steve
As some of these issues are too serious, I'm not sure if my merging &
build may have some problem...
If someone want to get a look, I've merged several Steve's develop tree
with Daniel's develop-vrp, and also merged by hand some other small
fixes and contributions I found interesting like Dave Potts and others,
that I'm testing as I have free time. You can find everything here:
https://github.com/ZupoLlask/pgrouting/tree/develop.
Helder Alves
On Sun, Jan 5, 2014 at 8:28 PM, Helder Alves <helderalvespt@gmail.com
<mailto:helderalvespt@gmail.com>> wrote:
Hi Steve,
I'm already beyond that stage but thanks anyway! ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Steve/Daniel,
Regarding my assumptions regarding pgr_apspjohnson, they seem to be
wrong. Can you please elaborate a little bit on exactly which data
must be fed into pgr_apspjohnson?
From the pgRouting examples I read, it seems to return the
equivalent to the distance matrix used by pgr_TSP however I don't
understand exactly which part of a routable table must be queried in
a viable way for an algorithm to be able to infer which nodes have
to be routed. Can you help me with this one?
Thanks!
Helder Alves
On Sun, Jan 5, 2014 at 7:52 PM, Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:
On 1/5/2014 2:16 PM, Helder Alves wrote:
Hi Daniel,
Regarding pgr_apspjohnson, I came to the conclusion that SQL
query
passed into pgr_apspjohnson must already return a shortest
path distance
matrix including all the stop points we want to optimize. Am
I getting
it right?
What I'm about to try now is to unnest the distance matrix
generated for
pgr_TSP to feed pgr_apspjohnson...
You might be able to use something like this to convert the
distance matrix into a table:
with dm as (
select '{{1,2,3,4,5},
{6,7,8,9,10},
{11,12,13,14,15},
{16,17,18,19,20},
{21,22,23,24,25}}'::int as dm
select i, j, dm.dm <http://dm.dm>[j][i]
from generate_series(1, 5) i,
generate_series(1, 5) j,
dm;
-Steve
Problem was that from all my previous reading I thought that
at some
point APSP Johnson would itself generate the routing graphs,
what seems
not to be the case, if my understanding from the source code
is right...
Meaning APSP Johnson only takes care of the total route
minimum cost
(permutations) avoiding the problem of TSP with negative costs.
Please let me know if I made foolish assumptions! ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Helder Alves
_________________________________________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.__org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
