On Wed, Dec 11, 2013 at 12:18 AM, Petros Apotsos <petrosapotsos@gmail.com>wrote:
Dear list,
I am sure this has been answered already, but I am new to this list (and
pgRouting altogether) and haven't been able to find a suitable answer. The
question is:
I am using the 2nd version of the function pgr_trsp to do sequential
routing between GPS signals on a road network. How can I convert the
pgr_costresult to a useful geometry type (LINESTRING would be great)?
Hi Petros,
This chapter in the workshop might answer your question:
http://workshop.pgrouting.org/chapters/wrapper.html#return-route-with-network-geometry
Bonus questions:
-What type EXACTLY is the result of this function? Is it a SELECT list? An
array?
The result type is a "set of records":
http://docs.pgrouting.org/2.0/en/src/common/doc/types/cost_result.html#type-cost-result
You can use the result like a SELECT result.
-Why the heck doesn't pgRouting produce (or include respective functions
to do so) geometry results, but rather this kind of results. In most cases
(if not all) it comes down to actually needing such an output.
Because there is such a variety of network data and each data might have
different column names, projections, etc.. For Dijkstra algorithm you even
don't need a geometry. Your network could be something totally abstract.
So pgRouting tries to make as less assumptions as possible.
In the previous version there were several "wrapper" functions, but it was
extra work to maintain them.
It's really easy to link your result with the original table, so once you
know how it works, you will hopefully agree.
Hope this helped.
Regards.
Daniel
Thank you all in advance,
*Petros Apotsos*
Rural & Surveying Engineer
Technical Chamber of Greece Registry Number 96798
Τ: 2310 220345
F: 2310 220346
Ermou 18A, Postal Code 54624
Thessaloniki, GREECE
__________ Information from ESET Smart Security, version of virus
signature database 9154 (20131210) __________
The message was checked by ESET Smart Security.
http://www.eset.com
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
