Is pgr_createTopology deterministic in how it numbers nodes in a built topology?
Best,
Steve
Best,
Steve
topology?
Stephen,
What do you mean by this?
If you build a topology on the same edge table twice, do we guarantee that the nodes numbers will be identical?
I think the answer is NO, on line:303 of src/common/sql/pgrouting_topology.sql there is no "order by" clause. This would need to be added to make it deterministic because relational set theory does not guarantee order of records in a query without explicitly including and "order by" clause.
Write a bug if you think this is needed and state why.
-Steve
Cool, I’ll write a ticket. It would be mostly useful in the case of e.g. tutorial development.
Best,
Steve
On Sat, Nov 30, 2013 at 2:46 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
topology?Stephen,
I think the answer is NO, on line:303 of src/common/sql/pgrouting_topology.sql there is no “order by” clause. This would need to be added to make it deterministic because relational set theory does not guarantee order of records in a query without explicitly including and “order by” clause.
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Done. Issue #220.
Best,
Steve
On Sat, Nov 30, 2013 at 2:52 PM, Stephen Mather <stephen@smathermather.com> wrote:
Best,
Steve
topology?Stephen,
-Steve
I don’t know if I did this correctly, but:
https://github.com/pgRouting/pgrouting/pull/221
On Sat, Nov 30, 2013 at 4:43 PM, Stephen Mather <stephen@smathermather.com> wrote:
Done. Issue #220.
Best,
Steve
Best,
Steve
topology?Stephen,
-Steve
Hi Stephen,
Thanks for looking into this!
I just wanted to mention that it would be better, if a pull request would be in “develop” branch (I already didn’t look careful recently and just clicked “merge pull request” accidentally and it was merged into master branch).
So in general making changes in “develop” branch is better, because “develop” might be also ahead of “master” anyway.
Daniel
On Tue, Dec 3, 2013 at 11:54 AM, Stephen Mather <stephen@smathermather.com> wrote:
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
Done. Issue #220.
Best,
Steve
Best,
Steve
topology?Stephen,
-Steve
Resubmitted on the correct branch. In nominal tests here (not a full rebuild but just a loading of that sql file), it seems to retain node numbers very nicely.
Best,
Steve
On Tue, Dec 3, 2013 at 12:15 AM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Stephen,
I just wanted to mention that it would be better, if a pull request would be in “develop” branch (I already didn’t look careful recently and just clicked “merge pull request” accidentally and it was merged into master branch).So in general making changes in “develop” branch is better, because “develop” might be also ahead of “master” anyway.
Daniel
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Done. Issue #220.
Best,
Steve
Best,
Steve
topology?Stephen,
-Steve
