In a quoted string like 'string with '' in it' you have to double the quote marks for the embedded quote.
Hi Stephen,
Thanks for your reply.
Sorry for the incomplete information...
Running que code:
DO $$
DECLARE
i integer;
BEGIN
FOR i IN (select nn from numero)
LOOP
EXECUTE
'create table contagio' || i || ' as
SELECT id1 as no, cost as cost' || i ||
' FROM pgr_drivingdistance('
SELECT gid AS id,
source,
target,
tempo::float8 AS cost
FROM lisboa',
18 ,
30,
false,
false)'
return the error:
ERROR: syntax error at or near "SELECT"
LINE 11: SELECT gid AS id,
I think I understand what's wrong. I have a query string inside a query
string.
I tried to solve this using $$, but it doesn't work.
If I run:
SELECT *
FROM pgr_drivingdistance($$
SELECT gid AS id,
source,
target,
FROM lisboa$$,
18 ,
30,
false,
false);
It works fine. But if this code comes after EXECUTE as a query string,
it doesn't work (a query string inside a query string)...
Thanks fro any help,
Carla
ubuntu 12.04
postgis version:
"2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
pgrouting version:
"(2.0.0-rc1,v2.0.0-beta,50,6a63bc1,develop,1.46.1)"
END LOOP;
END;
return the error:
string.
If I run:
SELECT *
SELECT gid AS id,
source,
target,
FROM lisboa$$,
18 ,
30,
false,
false);
Carla
ubuntu 12.04
postgis version:
pgrouting version:
2013/9/27 Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>>
Hi Carla,
It would be useful if you posted what your error message is.
I suspect the the following lines:
needs to get changed to:
> SELECT id1 as no, cost as cost,' || i || '::integer
-Steve W
On 9/27/2013 5:59 AM, Carla Rebelo wrote:
Dear all,
I need to calculate the catchment area for a number of nodes
(schools).
I'm using pgr_driving distance and adding geometry from the
nodes table.
My code creates a table for each destination. Example (for node
71197):
drop table if exists contagio71197;
create table contagio71197 as
SELECT foo.id1 as no, foo.cost as cost71197, vertices_tmp.the_geom
FROM vertices_tmp inner join pgr_drivingdistance('
SELECT gid AS id,
source,
target,
FROM lisboa',
71197,
20,
false,
false) as foo
on (vertices_tmp.id <http://vertices_tmp.id>
<http://vertices_tmp.id> = foo.id1);
------------------------------__---
Now, since I have around 100 destinations, I tried to loop
through the
list of nodes.
I wrote the following code (column numero.nn contains the list
of nodes
which constitute the destinations:
DO $$
DECLARE
i integer;
BEGIN
LOOP
EXECUTE
SELECT gid AS id,
source,
target,
FROM lisboa', '
|| i || ' ,
30,
false,
false)'
END LOOP;
END;
------------------------------__------------------------------__---------------
Now, I know where the problem is: the query string after EXECUTE
has a
function that uses another query string as an input
(pgr_drivingDistance(text sql, ......)
Probably there's a simple solution, but I can't get it.
Any help.
Thank you very much.
Carla
_________________________________________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.__org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
