Hi
Great news on getting version 2.5 out
Looking around the documentation I have noticed the function pgr_maxFlow, its only listed as a proposed function.
Just how stable is it ? Was it ever finished ? Does it work?
regards
Dave.
Hi
regards
Dave.
Hi Dave,
The function is listed as “stable proposed”, and the info box on top explains a bit, what we mean with this:
http://docs.pgrouting.org/latest/en/proposed.html#stable
Often those functions are ready, but they are missing some extra work on tests or documentation for example.
Or they have been developed during GSoC, and we hope to get some feedback from real-world use cases.
Maybe by “hiding” these functions a bit, only few people find and try them. But feedback is actually what we hope for.
pgr_maxFlow falls into the GSoC category, and some feedback would be great!
Best regards,
Daniel
On Mon, Sep 25, 2017 at 4:27 PM, Dave Potts <mrdapotts@gmail.com> wrote:
Hi
regards
Dave.
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: https://georepublic.info
HiSo its a workable function, but there may be bugs in it!
From a look at the source code, it seems that most of work is done by the boost library and any possible errors would be in the calling interface which is a mixture of C/C++
On 25 September 2017 at 09:21, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Dave,
http://docs.pgrouting.org/latest/en/proposed.html#stableOften those functions are ready, but they are missing some extra work on tests or documentation for example.
Maybe by “hiding” these functions a bit, only few people find and try them. But feedback is actually what we hope for.pgr_maxFlow falls into the GSoC category, and some feedback would be great!
Best regards,
Daniel
Hi
regards
Dave.
Hi
Ignore previous email
Thanks for the prompt reply
There is no support for this code, if I find any bugs you would be interested in any solutions, but otherwise I am on my own
Dave
Hi Dave,
Best regards,
Daniel
Hi
regards
Dave.
Like in every other function, too ![]()
That's right.
Vicky also added a Boost logo on every function's documentation site, if it
makes use of Boost Library:
http://docs.pgrouting.org/latest/en/pgr_maxFlow.html#pgr-maxflow
Like with every function, there is support by wwriting to the list or
reporting a bug on Github.
There is no guaranteed time until a bug gets fix, but it depends on the
case and how easy/difficult it is.
If support or bug fixes are important for you, and if you're in the lucky
situation to be able to afford commercial support, then you are definitely
not on your own. ![]()
Best regards,
Daniel
Dave
which is a mixture of C/C++On 25 September 2017 at 09:21, Daniel Kastl <daniel@georepublic.de>
wrote:Hi Dave,
The function is listed as "stable proposed", and the info box on top
Maybe by "hiding" these functions a bit, only few people find and try
great!Best regards,
DanielOn Mon, Sep 25, 2017 at 4:27 PM, Dave Potts <mrdapotts@gmail.com> wrote:
Hi
pgr_maxFlow, its only listed as a proposed function.Just how stable is it ? Was it ever finished ? Does it work?
regards
Dave.
https://lists.osgeo.org/mailman/listinfo/pgrouting-users--
Web: https://georepublic.info_______________________________________________
https://lists.osgeo.org/mailman/listinfo/pgrouting-users_______________________________________________
Sorry for the late response.
Initially was under the “Experimental” category, I went through the code, cleaned code & fixed pgr_edgeDisjointPaths that is why there is a:
Breaking change on:
And I moved them up to the “Stable” section.
On version 2.x only the the functions on 2.0 are in the main area of the documentation, everything new either is “Stable” or “Experimental”
The Stable ones are the most likely to be moved to the main area of the documentation on version 3.0
Everything done by GSoC Students is on experimental section unless there has being a procedure like the one I did on the max flow functions.
And, like Daniel mentioned, feedback is important.
And you are not on your own, i’ve being feeling that way for this last 2 years of code rewrite, but now I am into a point where I think the internal code is stable and more members of the community can participate in bug fixing, more rewriting, or adding new functions with ease. For example, currently, I am on gitter [1], I am still working with Vidham, and Anthony Tasca, with the focus on the functions needed to make pgr_trsp work correctly.
A way to learn how pgRouting works internally & contribute would be to read code and document the code. (Just by reading 2.0 code I knew it had bugs)
Vicky
[1] https://gitter.im/pgRouting/pgrouting
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
