I’m following pgrouing workshop. I followed steps as they said I executed the command
osm2pgrouting -file "data/sampledata.osm" \
-conf "/usr/share/osm2pgrouting/mapconfig.xml" \
-dbname routing \
-user postgres \
-clean
and check the database using
`psql -U postgres -d routing -c "\d"`
`but create vertices_tmp , vertices_tmp_id_seq tables not created...`
`How do I do create this tables ?`
On Sat, Jun 1, 2013 at 2:16 PM, Sithila Konara
<sithilamadushanka@gmail.com>wrote:
I'm following pgrouing workshop. I followed steps as they said I executed
the command
-dbname routing \
-user postgres \
-clean
They are created by osm2pgrouting.
When you run it, didn't it return any errors?
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
