On 4/10/2013 8:48 AM, Luís de Sousa wrote:
Hi Stephen and Daniel,
I'd be glad to contribute, I believe I can invest a few hours per week.
Besides that I'm working on a project where K-Shortest will be used, I
can try to source some funding around it.
Luis,
Funding would be great if you can arrange it, K-Shorest path is one of the algorithms that we would like to add to 2.0 so we might be able to accelerate getting that moved into sew-devel-2_0 branch.
Regarding contributing, do you have any area(s) that you would like to work on. We can use effort in all areas. I do not where your skills are on the spectrum from developer <----> user, but there is no shortage of tasks across the board.
-Steve
Luís
On 9 April 2013 15:56, Stephen Woodbridge <woodbri@swoodbridge.com
<mailto:woodbri@swoodbridge.com>> wrote:
Hi All,
The sew-devel-2_0 branch is what I'm currently working on. I do not
have a release date because it depends on how much we decide to
integrate into this branch and how much funding we can raise to
support this effort.
My general development goals is to try an make sure that at the end
of each day (UTC-0500) that the branch is stable and compiles and
builds on Linux and Windows.
Currently it:
* works with PostGIS 2.0
* has had the source tree restructured to better support multiple devs
* has TRSP merged into the tree
* has had TSP solver replaced to remove GAUL dependency
* has a new doc system integrated into the source tree
* has a new test infrastructure integrated into the source tree
* has some tests have been added to the source tree
* has some bugs fixed
* has some new graph analytic tools for detecting graph connectivity
issues
* installs as a postgresql extension on PG9.1+
* has probably a few other things that I'm not remembering.
Things that will change over time in this branch:
* all functions will get a pgr_ prefix
* all functions will get reviewed and probably restructured to be
more consistent and allow users to easily switch between function
* more algorithms from pull requests and GSoC projects will get
pulled into the main respository
* rewrite driving distance to drop CGAL and use postgis functions
Look at this to get an idea:
https://github.com/pgRouting/__pgrouting/wiki/2.0-__Development-Plan
<https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Plan>
You can see a lot has been done and there is a lot more to do. A lot
of the infrastructure work has been tackled and some of the low
hanging fruit has been picked. Any offers for funding would be
greatly appreciated and could help accelerate and/or prioritize
features.
This is currently stable and fairly close to the 1.0.5 functionality
so if you are inclined to give it a try we would love to here about
on what works and doesn't, etc.
-Steve
On 4/9/2013 9:22 AM, Luís de Sousa wrote:
Hi Daniel, thanks for the update.
I know this is a tricky question, but is there any expected date for
this new release?
Thank you,
Luís
On 9 April 2013 13:05, Daniel Kastl <daniel@georepublic.de
<mailto:daniel@georepublic.de>
<mailto:daniel@georepublic.de>__>
wrote:
A new release is currently worked on.
There is lots of discussion on the developer list and if
you want to
try out, you could checkout from Github repository and
compile using
the following branch:
https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0
<https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
_________________________________________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.__org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
