Release pgRouting 2.2.0 RC1 is available for testing. You can read about it and download from here:
https://github.com/pgRouting/pgrouting/releases/tag/pgrouting-2.2.0-RC1
The release announcement also has links to the issues closed and the new documentation. This release brings the product another step closer to release. Links for downloading it are at the bottom of the release announcement on the link above.
Many thanks for all the work you have done testing and Vicky has put into these releases.
WE NEED YOUR HELP! Things that you can do:
* please check any issues you reported against prior releases
* read and report documentation issues
* download, compile, and try it out and report any issues that you find
* Mac OS-X testing. This is important for someone to compile, install and make some simple tests. Our normal OS-X guru is busy and it would be great to get some confirmation that this is working.
As you can see we are moving fast and your support is critical as we make changes and releases. Please give us a helping hand with this release.
Best regards,
-Steve
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Am 2016-03-31 um 02:15 schrieb Stephen Woodbridge:
Best regards,
-Steve
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Builds fine in Fedora 23 and Rawhide!
Greetings, Volker
Thanks for the information.
Vicky
- please check any issues you reported against prior releases
- read and report documentation issues
- download, compile, and try it out and report any issues that you find
- Mac OS-X testing. This is important for someone to compile, install
Best regards,
-Steve
Greetings, Volker
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
