On 7/23/2013 9:43 AM, Yaron Lev wrote:
thanks a lot for your in-depth explanation, it helped me a lot and indeed i
was referring to the c/c++ part.
the basic question i am trying to understand, how beneficial it will be to
increase the DB instance size (cpu wise) (i am using AWS).
just to be clear, and re-iterating, each request has two basic parts:
1. grab data, and build the graph on the db - this is done on the
PostgreSQL db, and therefor will benefit from multi-core environment.
correct
2. solving and returning the answer -
here i am a little lost. PostgreSQL allow integration of C, i would expect
then, that these extensions(pgRouting code) will also benefit from
(i.e each request will use a different thread if needed, and on different
core if needed)
yes, each request runs in a separate db instance or thread.
so in short, will part 2, also benefit from increasing the instance size(i
understand it consumes roughly 30% of resources needed to complete the
request)?
The C/C++ code *mostly* does its own memory allocation and does not rely on the memory pooling that postgresql provides. some parts of the progress to use this but the graphs and solution memory is allocated outside the postgresql memory pooling.
In general if you are not running a lot of other processes on the server you can allocate more memory to postgresql, how much memory the graphs use depends on the typical size of a graph. I have never tried to figure this out. I would go with the standard memory sizing suggestions you can find for postgresql tuning. If you need a number to start with, on an 8GB memory system you might try 4GB in shared buffers and watch it under load with top to see how memory is being used and how much swap is getting used, how large the processes are getting, etc. and then make adjustments from there.
Also you can optimize your data storage by clustering on the edge table spatial index. This will minimize IO when selecting edges for a graph because edges that are spatially close together will get clustered on pages, and once you need one edge on a page it is likely you will need multiple edges on that page and page caching is done in the shared buffers.
-steve
again, many thanks for your help.
On Tue, Jul 23, 2013 at 3:39 PM, Stephen Woodbridge <woodbri@swoodbridge.com
wrote:
On 7/23/2013 7:55 AM, Yaron Lev wrote:
i was looking for some information about weather or not pgRouting is
utilizing more than one core if available.
from the limited testing i made, and from googling (i found very little
refrences), i think pgRouting does not support multi-core processing as of
now.
i will appreciate if anyone can confirm it, or give any information about
it.
PgRouting is built on top of Postgresql so to the extent that postgresql
can use multiple cores to process multiple requests we do. I you are asking
if the routing algorithm itself is run in threads or using something like
parallel graph algorithms? the answer is no.
Also you should be aware the solving the graph is less then 50% of the
cost of answering a query because we have to query the database for the
edges, build the graph, solve the graph and return the results back to the
client. selecting the edges and building the graph likely take 2/3rds of
the processing time for a given query. The edge selection is probably done
in a separate core/thread/process by the database from that that the rest
of the processing is taking place in.
-Steve
______________________________**_________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.**org <Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
