Hi guys
Those who posted in February about PGRouting and Postgresql 9.2, I have built pgrouting from github against postgresql 9.2 for Windows 32 bit.
Anyone interested please contact me.
Pieter
Hi guys
Pieter
On 3/3/2013 2:49 AM, Pieter du Plooy wrote:
Hi guys
built pgrouting from github against postgresql 9.2 for Windows 32 bit.Anyone interested please contact me.
Pieter
Hi Pieter,
Can you send me details on how you did this?
I have build PostGIS 2.0 for Windows 64 and I will be doing the same for Windows 32 and also will be pgRouting for both of these. I also hope to get pgRouting to install as an extension under postgresql.
My end result is that I want to check in the build and document this process and scripts and check it into git so we have a repeatable process that anyone can replicate for building pgRouting.
-Steve
Stephen
I essentially took the pgrouting4w-master from https://github.com/sanak/pgrouting4w, and followed the guide from the Build.mingw file. I had problems building boost, but followed http://stackoverflow.com/questions/5299468/unable-to-build-boost-libraries-with-gcc to build bjam and then boost.
I am attaching an winrar file with the dll’s as well as the sql files which I modified according to Linux procedures as Postgres 9.2 uses LANGUAGE ‘c’ instead of LANGUAGE ‘C’ .
I would also like the ability to have pgrouting to be installed as Postgres 9.2 extensions in stead of doing a psql -f on all the sql files, but I didnt know how to do that, otherwise I also would have done that.
I personally feel the hassles building a 64 bit version outweighs the pro’s but that’s just me.
Pieter
pgrouting_postgis92.rar (748 KB)
On Sun, Mar 3, 2013 at 5:51 PM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Hi guys
Pieter
Hi Pieter,
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
On 3/5/2013 12:15 AM, Pieter du Plooy wrote:
Stephen
to build bjam and then boost.I am attaching an winrar file with the dll's as well as the sql files
LANGUAGE 'c' instead of LANGUAGE 'C' .
Pieter,
Thank you for this it will save me a bunch of time once I tackle this.
that.
I have built an extension for some other code, and it is high on my list to get extensions working for pgRouting.
pro's but that's just me.
I have gone through the process of building postgis on windows 64 bit and it is a bit tedious. I'm hoping that we can get this automated in the future, but we have a lot of other stuff to work on first.
Best regards,
-Steve
Pieter
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>> wrote:On 3/3/2013 2:49 AM, Pieter du Plooy wrote:
Hi guys
I have
Pieter
Hi Pieter,
hope to get pgRouting to install as an extension under postgresql.My end result is that I want to check in the build and document this
process that anyone can replicate for building pgRouting.Thanks,
-Steve_________________________________________________
Pgrouting-users@lists.osgeo.__org
<mailto:Pgrouting-users@lists.osgeo.org>
http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Steve
On a side note, I got extremely frustrated that the binaries Sanak had was only for older Postgres versions so thats why I decided to do my own one.
If I had the knowledge, I would have done it in VC, but wasn’t really in the mood to go through that instructions as well. LOL.
I have read on the Postgis Forums that they were planning to include it with Postgis, but haven’t seen anything further on it.
Pieter
On Tue, Mar 5, 2013 at 7:51 AM, Stephen Woodbridge <woodbri@swoodbridge.com> wrote:
Stephen
to build bjam and then boost.I am attaching an winrar file with the dll’s as well as the sql files
LANGUAGE ‘c’ instead of LANGUAGE ‘C’ .Pieter,
that.I have built an extension for some other code, and it is high on my list to get extensions working for pgRouting.
pro’s but that’s just me.I have gone through the process of building postgis on windows 64 bit and it is a bit tedious. I’m hoping that we can get this automated in the future, but we have a lot of other stuff to work on first.
Best regards,
-StevePieter
<woodbri@swoodbridge.com mailto:[woodbri@swoodbridge.com](mailto:woodbri@swoodbridge.com)> wrote:
Hi guys
I have
Pieter
Hi Pieter,
-Steve
mailto:[Pgrouting-users@lists.osgeo.org](mailto:Pgrouting-users@lists.osgeo.org)
