[pgrouting-users] pgRouting could not get result on Windows7
Dear all,
I has implemented and install PostgreSQL/PostGIS and pgRouting on windows 7 as showing the detail of version belows;
PostgreSQL = “PostgreSQL 9.3.5, compiled by Visual C++ build 1600, 32-bit”
PostGIS = “POSTGIS=“2.1.3 r12547” GEOS=“3.4.2-CAPI-1.8.2 r3924” PROJ=“Rel. 4.8.0, 6 March 2012” GDAL=“GDAL 1.10.0, released 2013/04/24” LIBXML=“2.7.8” LIBJSON=“UNKNOWN” TOPOLOGY RASTER”
pgRouting =“(2.0.0,pgrouting-2.0.0,0,d6ed2cb,master,1.46.1)”
After I create all needed column into my road table then use pgr_dijkstra() function. But I could not get the routing result. The table showing empty data.
My road data structure is showing below;
– Table: public.ways
– DROP TABLE public.ways;
CREATE TABLE public.ways
gid integer NOT NULL DEFAULT nextval(‘ways_gid_seq’::regclass),
the_geom geometry(MultiLineString,3857),
source integer,
target integer,
reverse_cost double precision,
length double precision,
x1 double precision,
y1 double precision,
x2 double precision,
y2 double precision,
CONSTRAINT ways_pkey PRIMARY KEY (gid)
WITH (
OIDS=FALSE
ALTER TABLE public.ways
OWNER TO postgres;
– Index: public.source_idx
– DROP INDEX public.source_idx;
CREATE INDEX source_idx
ON public.ways
USING btree
(source);
– Index: public.target_idx
– DROP INDEX public.target_idx;
CREATE INDEX target_idx
ON public.ways
USING btree
(target);
– Index: public.ways_geom_gist
– DROP INDEX public.ways_geom_gist;
CREATE INDEX ways_geom_gist
ON public.ways
USING gist
(the_geom);
– Index: public.ways_source_idx
– DROP INDEX public.ways_source_idx;
CREATE INDEX ways_source_idx
ON public.ways
USING btree
(source);
– Index: public.ways_target_idx
– DROP INDEX public.ways_target_idx;
CREATE INDEX ways_target_idx
ON public.ways
USING btree
(target);
What I am missing, any ideas?
Bomp
Sittichai Choosumrong (Ph.D)
Lecturer at Faculty of Agriculture, Natural Resources and Environment,
Department of Natural Resources and Environment,
Geography
99 Moo 9 Tambon Tha Pho,
Amphoe Muang
Phitsanulok Thailand 65000
Office: +66 55 962753
Mobile: +66 95-635-8102
email: sittichaic@nu.ac.th
Hi Bomp,
Because you mention “Windows 7” in the subject, do you want to say that it worked before, for example on Linux?
If you use the sample data of the documentation [1], does it return an empty table as well? You can run the sample queries [2] to verify it works or not.
If the sample queries with the sample data work, then you may have a problem with your data.
Just one remark (which shouldn’t prevent you from running pgr_dijkstra though): your geometry is “multilinestring”. If you really have multilinestrings, then you would have a problem to define source and target. Otherwise just make it ordinary linestrings.
Best regards,
Daniel
[1] http://docs.pgrouting.org/2.0/en/doc/src/developer/sampledata.html#sampledata
[2] http://docs.pgrouting.org/2.0/en/src/dijkstra/doc/index.html#examples
On Thu, Aug 7, 2014 at 10:07 AM, sittichai choosumrong <sittichai.ocu@gmail.com> wrote:
Dear all,
source integer,
target integer,
WITH (
OIDS=FALSE
OWNER TO postgres;
ON public.ways
USING btree
(source);
ON public.ways
USING btree
(target);
ON public.ways
USING gist
(the_geom);
ON public.ways
USING btree
(source);
ON public.ways
USING btree
(target);
Bomp
Geography
Amphoe Muang
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
Hi Daniel,
Now it work!! Thank you. The problem is from my data because the geometry is “multilinestring”
I have to change to “linestring”
Best regards,
Bomp
P.S. If you need any help about pgRouting workshop on FOSS4G-ASIA in Thailand this years (http://www.foss4g-asia.org/2014/programmenu/workshops/), please feel free to tell me what can I help you?
On Thu, Aug 7, 2014 at 3:25 PM, Daniel Kastl <daniel@georepublic.de> wrote:
Hi Bomp,
Best regards,
Daniel
Geography
Amphoe Muang
Dear all,
source integer,
target integer,
WITH (
OIDS=FALSE
OWNER TO postgres;
ON public.ways
USING btree
(source);
ON public.ways
USING btree
(target);
ON public.ways
USING gist
(the_geom);
ON public.ways
USING btree
(source);
ON public.ways
USING btree
(target);
Bomp
Geography
Amphoe Muang
Hi Daniel and all list,
Again problem. I downloaded OSM data and save as shapefile using projection EPSG:3857.
I try to use many data but I still could not get result.
Actually, pgRouting can run on Windows7 but the problem is when I implement the road network data.
I just realise after I test with the same data in difference OS (Ubuntu, Windows8 and Windows7)
Ubuntu and Windows8 is work well but the problem is;
On Windows7, the system cannot get the correct topology after use command
‘SELECT pgr_createTopology(‘ways’, 0.00001, ‘the_geom’, ‘gid’);’
You can see how its strange in the image files in this mail.
With the same data, ‘topo_correct.jpg’ showing the topology node which created on Window8 and we get the node for all junction which have only one ID values.
But, ‘topo_error.jpg’ showing the topology node which created on Windows7 and in one node its have ID values depend on how much edge connect on that node.
I think because of the problem that why when I use pgRouting function I got only empty table without any error of calculating.
Any ideas?
Best regards,
Bomp
On Thu, Aug 7, 2014 at 3:37 PM, sittichai choosumrong <sittichai.ocu@gmail.com> wrote:
Hi Daniel,
Best regards,
Bomp
Geography
Amphoe Muang
Hi Bomp,
Best regards,
Daniel
Geography
Amphoe Muang
Dear all,
source integer,
target integer,
WITH (
OIDS=FALSE
OWNER TO postgres;
ON public.ways
USING btree
(source);
ON public.ways
USING btree
(target);
ON public.ways
USING gist
(the_geom);
ON public.ways
USING btree
(source);
ON public.ways
USING btree
(target);
Bomp
Geography
Amphoe Muang
