I am trying to convince my hosting provider (alwaysdata) to give me the ability to activate pgRouting in my PostgreSQL / PostGIS database.
His answer is : I can't because there is no readymade Debian package for pgRouting.
Does such a package already exists, or could it be possible to provide one ?
On Fri, Oct 14, 2011 at 1:00 AM, “Christophe Damour (SIGéal)” <sigeal@sigeal.com> wrote:
His answer is : I can’t because there is no readymade Debian package for pgRouting.
There are Ubuntu packages available in a Launchpad repository: https://launchpad.net/~georepublic/+archive/pgrouting
It shouldn’t be very difficult to build Debian packages based on them with some small modifications.
Yes, Daniel, I saw these Ubuntu packages, but as I am neither a Debian user nor a Ubuntu one, I can hardly handle this.
That is why I send a SOS to the users / dev community…
Christophe
On Fri, Oct 14, 2011 at 1:17 AM, “Christophe Damour (SIGéal)” <sigeal@sigeal.com> wrote:
I see. Well, if it’s easy or not depends probably on the Debian version you need the packages for, and the versions of required packages.
From my experience building the packages for Ubuntu there are versions it was a quite easy tasks, and some where I had troubles with dependencies.
Another question is, if your hosting provider requires an “official” Debian package available in a package repository, or if it can be an individually build.
It’s a Debian Lenny (5.0).
I suppose an “official” Debian package would be required, because of maintenance ease for the hosting provider…
Another issue is that this hosting provider uses PostgreSql V9, with which pgRouting is not compatible so far.
Christophe DAMOUR (SIGéal)
I asked the provider and he answered that an official Debian package was not absolutely required, but at least a package supported by pgRouting development team. Could this be possible ?
Also, what about PostgreSql 9 compatibility. Is this on the roadmap ?
On Sat, Oct 15, 2011 at 12:59 AM, “Christophe Damour (SIGéal)” <sigeal@sigeal.com> wrote:
Theoretically it is possible, but since most of my community work is on a volunteer base, I can only do this if I have enough spare time or if you’re able to sponsor the work or find a sponsor.
I use mainly Ubuntu and the new version that was released yesterday, should include PostgreSQL 9.0 as far as I remember.
So I’m also interested to make it work with 9.0 and will probably build packages for 11.10 in the next weeks. If it works with Ubuntu, it should also be compatible with PostgreSQL on Debian.
I am in the process of setting a virtual private server for my development needs.
As I can chose the linux distribution, I would like to know if you manage to build a pgRouting package for PostgreSQL 9.0 ?
Christophe
On Sat, Dec 10, 2011 at 12:19 AM, “Christophe Damour (SIGéal)” <sigeal@sigeal.com> wrote:
Hi Daniel,
Hi Christophe,
I have build packages for Ubuntu 11.10 with PostgreSQL 9.1, but haven’t published them yet on Launchpad.
And on OpenSuse 11.4 with PostgreSQL 9.0 it was also possible to compile pgRouting.
So I assume that PostgreSQL 9.0 and 9.1 are both OK.
I got the server up with Ubuntu 11.04.
I tried the following with no success :
Installation following pgRouting doc (http://www.pgrouting.org/docs/1.x/install_ubuntu.html)
It failed at step 2 (Comile pgRouting core), saying it couldn’t find POSTGRESQL_EXECUTABLE…
The postgresql executable path seems to be : /usr/lib/postgresql/8.4/bin
Intallation of your pgRouting package (postgresql-8.4-pgrouting_1.05-1~natty2_i386.deb)
It failed saying postgresql-8.4-postgis is not installed.
I installed indeed postgresql-8.4 (apt-get install postgresql-8.4), but when I try apt-get install postgresql-8.4-postgis, I get a “postgresql-8.4-postgis is not available” message.
As you understand, I am quite a linux newbie, so I apologize for stupid questions…
Any hint appreciated.
Christophe
Hi Daniel,
Hi Christophe,
Can you make sure that you have the “multiverse” repository enabled? It could be the reason, that you can’t find PostGIS package.
Daniel
On Sat, Dec 10, 2011 at 7:20 PM, “Christophe Damour (SIGéal)” <sigeal@sigeal.com> wrote:
Hi Daniel,
Christophe
Hi Daniel,
Hi Christophe,
