Vicky has release pgRouting 2.2.0 beta1 from the develop branch. You can read about it and download from here:
https://github.com/pgRouting/pgrouting/releases
This fixes a couple of critical release packaging issues.
The release announcement also has links to the new documentation. This release has lots of fixes and some new features that I think you will find interesting and useful. Links for downloading it are at the bottom of the release announcement on the link above.
Many thanks for all the work Vicky has put into these releases.
WE NEED YOUR HELP! Things that you can do:
* read and report documentation issues
* download, compile, and try it out and report any issues that you find
* Mac OS-X testing. This is important for someone to compile, install and make some simple tests. Our normal OS-X guru is busy and it would be great to get some confirmation that this is working.
As you can see we are moving fast and your support is critical as we make changes and releases. Please give us a helping hand with this release.
Best regards,
-Steve
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Hi List,
When upgrading to a different version off Postgis, they supply an upgrade script to update the current database to the new release.
Will pgroute 2.2 have a script as well?
D
4 March 2016 01:13, "Stephen Woodbridge" <woodbri@swoodbridge.com> wrote:
from here:
Best regards,
-Steve
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
ggis42
Hi Dave:
This is what gets installed (beta1):
– Installing: /usr/lib/postgresql/9.3/lib/libpgrouting-2.2.so
– Installing: /usr/share/postgresql/9.3/extension/pgrouting–2.2.0.sql
– Installing: /usr/share/postgresql/9.3/extension/pgrouting.control
– Installing: /usr/share/postgresql/9.3/extension/pgrouting–2.0.0–2.2.0.sql
– Installing: /usr/share/postgresql/9.3/extension/pgrouting–2.0.1–2.2.0.sql
– Installing: /usr/share/postgresql/9.3/extension/pgrouting–2.1.0–2.2.0.sql
V.
Date: Fri, 4 Mar 2016 09:56:27 +0000
To: pgrouting-dev@lists.osgeo.org
Subject: [pgrouting-dev] Upgrading to 2.2
Hi List,
D
pgrouting-dev mailing list
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Thanks Vcky
Just how do you invoke the test sequence?
There does not seem to be a test target in the makefile
Dave,
4 March 2016 13:54, “Vicky Vergara” <vicky_vergara@hotmail.com> wrote:
Hi Dave:
V.
Hi List,
D
The page https://github.com/pgRouting/pgrouting/wiki/Automated-Testing-(Unit-Tests)
refers to a python script for testing, but it seems to be missing any ideas?
Dave.
4 March 2016 19:37, dave.potts@pinan.co.uk wrote:
Thanks Vcky
Dave,
Hi Dave:
V.
Hi List,
D
Hi Dave,
There is never being a test target, (CMakelists needs to be improved)
http://docs.pgrouting.org/v2.2.0-beta1/doc/src/installation/install-dependencies.html#pgtap-pg-prove-perl-for-tests
how to test:
- this is the v2.0.0 style testing
tools/testers/algorithm-tester.pl
- I am gradually moving tests to use pgTap & pg_prove
Note: the CMakelists.txt does not check yet for that to exist
createdb pgr___test
sh ./tools/testers/pg_prove_tests.sh
dropdb pgr___test
hope it helps.
V.
Date: Fri, 4 Mar 2016 19:37:28 +0000
Subject: Re: [pgrouting-dev] Upgrading to 2.2
Thanks Vcky
Dave,
Hi Dave:
V.
Hi List,
D
_______________________________________________ pgrouting-dev mailing list pgrouting-dev@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
