I'm busy for the next few days so I will not have time to look at it until later this week.
What version of postgresql are you running?
select * from version();
I would google "postgresql array functions" and read up on these.There is a function that will tell you the dimensions of an array and maybe you need to print out some more notices to figure out what it is expecting.
Maybe someone else on the list wants to take a crack at this.
-Steve
On 2/25/2014 3:14 PM, Carsten Hogertz wrote:
Hi Steve,
have been busy the last days so I only check your Thursday's solution
right now. Still not working.
My function looks like this:
create or replace function pgr_makeDijkstraMatrix(thetbl text, sqlP
text, OUT dmatrix double precision, OUT ids integer)
as
$body$
declare
sql text;
sql2 text;
r record;
r2 record;
i integer;
j integer;
matrixl double precision;
begin
ids := '{}'::integer;
sql:='select node, id-1 as id from '||thetbl;
for r in execute sql loop
sql2:='select id1, array_agg(cost) as arow from (
SELECT id1, id2, cost
FROM pgr_kdijkstraCost('''||sqlP||''', '||r.node||
', (select array_agg(node) from '||thetbl||' where
id>'||r.id <http://r.id>||'), false, false)
) as foo group by id1 order by id1';
for r2 in execute sql2 loop
matrixl := '{}';
for i in 1..r.id <http://r.id> loop
matrixl := array_append(matrixl, dmatrix[i][r.id
<http://r.id>+1]);
end loop;
matrixl := array_cat(matrixl, r2.arow);
dmatrix := array_cat(dmatrix, array[matrixl]);
raise notice 'r2: %', r2;
raise notice 'r2.id1: %', r2.id1;
raise notice 'ids: %', ids;
--ids := ids || r2.id1;
ids := array_cat(ids, array[r2.id1]);
end loop;
end loop;
end;
$body$
language plpgsql stable cost 10;
create or replace function pgr_tspDijkstra(thetbl text, sql text,
start_id integer, end_id integer default (-1))
returns setof pgr_costResult as
$body$
declare
sid integer;
eid integer;
begin
return query with dm as (
select * from pgr_makeDijkstraMatrix( thetbl, sql )
ids as (
select (row_number() over (order by id asc))-1 as rnum, id
from (
select unnest(ids) as id
from dm
) foo
t as (
select a.seq, b.rnum, b.id <http://b.id>
from pgr_tsp(
(select dmatrix from dm),
(select rnum from ids where id=start_id limit
1)::integer,
(case when end_id = -1 then -1 else (select rnum
from ids where id=end_id limit 1) end)::integer
) a,
ids b
where a.id <http://a.id>=b.rnum
r as (
select array_agg(t.rnum) as rnum from t
select t.seq::integer,
t.rnum::integer as id1,
t.id::integer as id2,
dm.dmatrix[r.rnum[t.seq+1]+1][r.rnum[(t.seq+1)%array_length(r.rnum,
1)+1]+1]::float8 as cost
from t, dm, r;
end;
$body$
language plpgsql volatile cost 50 rows 50;
create or replace function pgr_tspDijkstraLen(thetbl text, start_id
$body$
begin
return query SELECT * FROM pgr_tspDijkstra(thetbl,
'SELECT id, source::integer, target::integer, length::double
precision AS cost FROM cgn_2po_4pgr',
start_id, end_id);
end;
$body$
language plpgsql stable;
AND the error I am getting:
NOTICE: r2:
(34304,"{0,5.3602868897,4.6782573327,5.6026971537,5.2062747797,5.0497181017,5.3147719797,5.0700916462,4.3220066797,4.8593618137,4.0002255227,6.055760592,12.5155379824,9.3170226155,8.72783427270001,5.9460446587,3.0868131677,5.1839796057,5.2301666167,2.1211198847,5.7037465591,2.7282842677,8.4758437557,11.1027935904,7.9434273599,7.8361619299,7.7610621969,7.4929139614,5.8106133327,5.9579132527,5.9888473034,6.5618433959,4.5013708887,1.9218516244,5.7559805232,5.2267081177,5.0968196707,4.8949133597,5.9137964962,4.2936059427,4.6948533593,3.4377318427,3.7991617067,4.1242444467,3.8858731777,3.9596393887,4.9192685996,4.6734033563,4.7511846457,4.4544981945,4.2748693367,3.411559417,6.6851381985,6.6744741285,6.9296475385,7.0136847108,7.1371500908,7.2719520708,6.6787720528,7.3530295908,6.8599596928,7.2216891568,7.4951304208,7.4404728868,8.1332243958,6.2736028029,6.963685048,6.0483763169,5.8653351624,5.6164044005,6.54979166,5.8783224469,6.533468297,5.8553434082,5.7676662122,6.267915357,5.22607939
03,3.745459072,6.352470342,5.4392033722,5.5562602522,5.3996670482,6.171297855,5.648779598,5.5653279855,5.671668653,5.3243595462,5.879320328,5.859442385,6.080574272,5.3767159992,6.170852717,5.3001119472,5.687201287,5.3573110752,3.586385579,5.566591422,5.5104826925,5.916268775,5.4418422465,5.4037394705,5.640889612,5.1407657702,4.5523677017,5.3873769863,3.601570449,2.978252449,4.8725960282,4.9817842222,5.2355359365,5.1227105795,5.177856607,5.098596533,5.1891181988,4.9327118245,4.4632330777,7.4879538737,4.8591269625,3.1339054377,5.8472818275,4.6043306952,3.3542942377,4.7660145915,6.6679095357,5.51150886,2.7404344677,5.9332075344,6.2019594857,5.266709364,5.4924174224,5.180577724,3.0277711677,6.2913260157,4.2862670877,5.5461328154,5.5809644644,5.1132029296,5.1904326724,4.8352505633,4.9641930171,5.1366240426,7.0699378037,3.1274712477,5.1487646306,5.2717034197,5.0200090866,3.0911490977,5.8984613527,5.1973381747,4.2427530627,6.7293864957,4.7943011637,5.1130266607,5.3948779287,4.7124246547,5.2
186371577,2.9723417287,2.3171875277,2.8159853427,4.7913513947,4.7863347867,3.4531342837,3.8161332287,5.8431115757,4.4873126817,5.6577494097,5.5867970832,9.4583860946,2.7784615917,5.4279953797,1.9376872717,5.0813930177,5.8860618114,6.2411339874,6.4536904614,6.0972641874,5.7247963284,5.9823452114,5.8316140784,5.2398164977,6.2963392357,5.5864457124,6.1599995178,5.2609646384,6.1012355027,6.4129483756,6.0056487896,5.0106569884,5.4239402364,6.1148656496,2.673828844,4.3332873457,3.2943586634,4.5834393467,7.278601561,3.5870893269,3.3299191554,4.1049776549,5.9256568037,6.2719334873,6.2594329923,5.5752581689,5.6058592867,6.1311384893,6.4726413519,5.8973941434,6.2572672069,5.9667442136,5.3965422637,7.2837623985,6.9586195092,7.1137641952,6.3682104908,7.8495628418,7.2245886958,6.2983788278,7.3509762248,6.9925366658,6.5600944468,6.936328733,6.616665943,6.738732443}")
CONTEXT: PL/pgSQL function "pgr_tspdijkstra" line 8 at RETURN QUERY
PL/pgSQL function "pgr_tspdijkstralen" line 3 at RETURN QUERY
NOTICE: r2.id1: 34304
NOTICE: ids: {}
ERROR: cannot concatenate incompatible arrays
DETAIL: Arrays with differing element dimensions are not compatible for
concatenation.
CONTEXT: PL/pgSQL function "pgr_makedijkstramatrix" line 26 at assignment
********** Fehler **********
SQL Status:2202E
Detail:Arrays with differing element dimensions are not compatible for
concatenation.
Kontext:PL/pgSQL function "pgr_makedijkstramatrix" line 26 at assignment
HOW comes? I really don't know what to do.
May you be so kind and try to help again?
Thanks
Carsten
2014-02-21 9:36 GMT+01:00 Carsten Hogertz <carsten.hogertz@gmail.com
<mailto:carsten.hogertz@gmail.com>>:
2014-02-20 23:25 GMT+01:00 Stephen Woodbridge
<woodbri@swoodbridge.com <mailto:woodbri@swoodbridge.com>>:
On 2/20/2014 4:59 PM, Carsten Hogertz wrote:
2014-02-20 22:47 GMT+01:00 Stephen Woodbridge
<mailto:woodbri@swoodbridge.__com
<mailto:woodbri@swoodbridge.com>>>:
On 2/20/2014 4:39 PM, Carsten Hogertz wrote:
2014-02-20 22:20 GMT+01:00 Stephen Woodbridge
<mailto:woodbri@swoodbridge.>____com
<mailto:woodbri@swoodbridge.com>>>>:
On 2/20/2014 3:54 PM, Carsten Hogertz wrote:
Thanks Steve,
coming home and adding your lines it
returns with an error:
NOTICE: r2:
(34304,"{0,5.3602868897 <tel:3602868897>
<tel:3602868897 <tel:3602868897>>
<tel:3602868897 <tel:3602868897> <tel:3602868897
<tel:3602868897>>>,4.6782573327 <tel:6782573327>
<tel:6782573327 <tel:6782573327>>
<tel:6782573327 <tel:6782573327>>>,5.6026971537 <tel:6026971537>
<tel:6026971537 <tel:6026971537>> <tel:6026971537
<tel:6026971537> <tel:6026971537
<tel:6026971537>>>,5.2062747797 <tel:2062747797>
<tel:2062747797 <tel:2062747797>>
<tel:2062747797
<tel:2062747797>>>,5.__0497181017,5.3147719797
<tel:3147719797> <tel:3147719797 <tel:3147719797>>
<tel:3147719797
<tel:3147719797>>>,5.__0700916462,4.____3220066797,4.__8593618137
<tel:8593618137>
<tel:8593618137 <tel:8593618137>>
<tel:8593618137
<tel:8593618137>>>,4.0002255227,6.______055760592,12.5155379824
<tel:5155379824>
<tel:5155379824 <tel:5155379824>>
<tel:5155379824
<tel:5155379824>>>,9.__3170226155,8.____72783427270001,5.__9460446587,____3.0868131677,5.__1839796057,__5.__2301666167,2.__1211198847,__5.__7037465591
<tel:7037465591>
<tel:7037465591 <tel:7037465591>>
<tel:7037465591
<tel:7037465591>>>,2.__7282842677,8.4758437557
<tel:4758437557> <tel:4758437557 <tel:4758437557>>
<tel:4758437557
<tel:4758437557>>>,11.__1027935904,7.____9434273599,7.__8361619299,7.____7610621969,7.__4929139614,5.____8106133327
<tel:8106133327>
<tel:8106133327 <tel:8106133327>>
<tel:8106133327
<tel:8106133327>>>,5.__9579132527,5.____9888473034,6.__5618433959
<tel:5618433959>
<tel:5618433959 <tel:5618433959>>
<tel:5618433959 <tel:5618433959>>>,4.5013708887 <tel:5013708887>
<tel:5013708887 <tel:5013708887>>
<tel:5013708887
<tel:5013708887>>>,1.__9218516244,5.____7559805232,5.__2267081177
<tel:2267081177>
<tel:2267081177 <tel:2267081177>>
<tel:2267081177
<tel:2267081177>>>,5.0968196707,4.______8949133597,5.9137964962
<tel:9137964962>
<tel:9137964962 <tel:9137964962>>
<tel:9137964962
<tel:9137964962>>>,4.__2936059427,4.____6948533593,3.__4377318427
<tel:4377318427>
<tel:4377318427 <tel:4377318427>>
<tel:4377318427
<tel:4377318427>>>,3.7991617067,4.______1242444467,3.8858731777,3.______9596393887,4.9192685996
<tel:9192685996>
<tel:9192685996 <tel:9192685996>>
<tel:9192685996
<tel:9192685996>>>,4.__6734033563,4.____7511846457,4.__4544981945,4.____2748693367,3.__411559417,6.____6851381985,6.__6744741285,6.____9296475385
<tel:9296475385>
<tel:9296475385
<tel:9296475385>>,7.__0136847108,7.____1371500908,7.__2719520708,6.__6787720528
<tel:6787720528>
<tel:6787720528
<tel:6787720528>>,7.__3530295908,6.__8599596928 <tel:8599596928>
<tel:8599596928
<tel:8599596928>>,7.__2216891568,7.____4951304208,7.__4404728868
<tel:4404728868>
<tel:4404728868
<tel:4404728868>>,8.__1332243958,6.____2736028029,6.__963685048,6.____0483763169,5.__8653351624
<tel:8653351624>
<tel:8653351624 <tel:8653351624>>,5.__6164044005
<tel:6164044005>
<tel:6164044005
<tel:6164044005>>,6.__54979166,5.__8783224469 <tel:8783224469>
<tel:8783224469
<tel:8783224469>>,6.__533468297,5.__8553434082 <tel:8553434082>
<tel:8553434082
<tel:8553434082>>,5.__7676662122,6.____267915357,5.__22607939
03,3.745459072,6.352470342,5.______4392033722,5.5562602522,5.______3996670482,6.171297855,5.______648779598,5.5653279855,5.______671668653,5.3243595462,5.______879320328,5.859442385
<tel:5.859442385>
<tel:5.859442385
<tel:5.859442385>>,6.____080574272,5.__3767159992,6.____170852717,5.__3001119472,5.____687201287,5.__3573110752,3.____586385579,5.__566591422,5.____5104826925
<tel:5104826925>,5.__916268775,5.____4418422465,5.__4037394705
<tel:4037394705>,5.____640889612,5.__1407657702,4.____5523677017,5.__3873769863,3.____601570449,2.__978252449,4.____8725960282
<tel:8725960282>,4.__9817842222,5.____2355359365,5.__1227105795,5.____177856607,5.__098596533,5.____1891181988,4.__9327118245,4.____4632330777,7.__4879538737,4.____8591269625,3.__1339054377,5.____8472818275
<tel:8472818275>,4.__6043306952
<tel:6043306952>,3.____3542942377,4.__7660145915,6.____6679095357
<tel:6679095357>,5.__51150886,2.____7404344677
<tel:7404344677>,5.__9332075344,6.____2019594857
<tel:2019594857>,5.__266709364,5.____4924174224,5.__180577724,3.____0277711677,6.__2913260157,4.____2862670877,5.__5461328154,5.____5809644644
<tel:5809644644>,5.__1132029296,5.____1904326724,4.__8352505633
<tel:8352505633>,4.____9641930171,5.__1366240426,7.____0699378037,3.__1274712477,5.____1487646306,5.__2717034197,5.____0200090866,3.__0911490977,5.____8984613527,5.__1973381747,4.__
2427530627,6.7293864957,4.______7943011637,5.1130266607,5.______3948779287,4.7124246547
<tel:7124246547>,5.2
186371577,2.9723417287 <tel:9723417287>
<tel:9723417287 <tel:9723417287>> <tel:9723417287
<tel:9723417287>
<tel:9723417287
<tel:9723417287>>>,2.3171875277,2.8159853427
<tel:8159853427> <tel:8159853427 <tel:8159853427>>
<tel:8159853427
<tel:8159853427>>>,__4.7913513947,4.7863347867
<tel:7863347867> <tel:7863347867 <tel:7863347867>>
<tel:7863347867
<tel:7863347867>>>,3.4531342837,__3.____8161332287,5.8431115757,4.______4873126817,5.6577494097
<tel:6577494097>,5.______5867970832
<tel:5867970832>,9.4583860946
<tel:4583860946>,2.______7784615917
<tel:7784615917>,5.4279953797,1.______9376872717
<tel:9376872717>,5.0813930177,5.______8860618114,6.2411339874,6.______4536904614,6.0972641874,5.______7247963284
<tel:7247963284>,5.9823452114,5.______8316140784
<tel:8316140784>,5.2398164977
<tel:2398164977>,6.______2963392357,5.5864457124,6.______1599995178,5.2609646384,6.______1012355027,6.4129483756,6.______0056487896,5.0106569884,5.______4239402364,6.1148656496,2.______673828844,4.3332873457,3.______2943586634,4.5834393467,7.______278601561,3.5870893269,3.______3299191554,4.1049776549,5.______9256568037,6.2719334873,6.______2594329923,5.5752581689,5.______6058592867,6.1311384893,6.______4726413519,5.8973941434,6.______2572672069,5.9667442136,5.______3965422637,7.2837623985,6.______9586195092,7.1137641952,6.______3682104908,7.8495628418,7.______2245886958,6.2983788278,7.______3509762248,6.9925366658,6.______5600944468,6.936328733,6.______616665943,6.738732443}")
RETURN QUERY
line 3 at RETURN
QUERY
RETURN QUERY
line 3 at RETURN
QUERY
NOTICE: ids: <NULL>
RETURN QUERY
line 3 at RETURN
QUERY
dimensions are not
compatible for
concatenation.
line 25 at
assignment
at RETURN QUERY
line 3 at RETURN
QUERY
I tried to write to Dose but he didn't
reply yet.
Does anyone have a clue?
Try adding the follow line after the "begin" line:
This should make sure the ids is initialized
as an empty
array of
integers.
-Steve
Again:
NOTICE: r2:
<tel:3602868897 <tel:3602868897>>,4.6782573327 <tel:6782573327>
<tel:6782573327 <tel:6782573327>>,5.6026971537
<tel:6026971537>>,5.2062747797 <tel:2062747797>
<tel:2062747797
<tel:2062747797>>,5.__0497181017,5.3147719797
<tel:3147719797>,5.____0700916462,4.3220066797,4.__8593618137 <tel:8593618137>,__4.0002255227,6.__055760592,12.__5155379824,9.__3170226155,8.__72783427270001,5.__9460446587,__3.0868131677,5.__1839796057,5.__2301666167,2.__1211198847,5.__7037465591,2.__7282842677,8.__4758437557,11.__1027935904,7.__9434273599,7.__8361619299,7.__7610621969,7.__4929139614,5.__8106133327,5.__9579132527,5.__9888473034,6.__5618433959,4.__5013708887,1.__9218516244,5.__7559805232,5.__2267081177,5.__0968196707,4.__8949133597,5.__9137964962,4.__2936059427,4.__6948533593,3.__4377318427,3.__7991617067,4.__1242444467,3.__8858731777,3.__9596393887,4.__9192685996,4.__6734033563,4.__7511846457,4.__4544981945,4.__2748693367,3.__411559417,6.__6851381985,6.__6744741285,6.__9296475385,7.__0136847108,7.__1371500908,7.__2719520708,6.__6787720528,7.__3530295908,6.__8599596928,7.__2216891568,7.__4951304208,7.__4404728868,8.__1332243958,6.__2736028029,6.__963685048,6.__0483763169,5.__8653351624,5.__6164044005,6
.__54979166,5.__8783224469,6.__533468297,5.__8553434082,5.7
676662122,6.__267915357,5.__22607939
03,3.745459072,6.352470342,5.____4392033722,5.5562602522,5.____3996670482,6.171297855,5.____648779598,5.5653279855,5.____671668653,5.3243595462,5.____879320328,5.859442385,6.____080574272,5.3767159992,6.____170852717,5.3001119472,5.____687201287,5.3573110752,3.____586385579,5.566591422,5.____5104826925,5.916268775,5.____4418422465,5.4037394705,5.____640889612,5.1407657702,4.____5523677017,5.3873769863,3.____601570449,2.978252449,4.____8725960282,4.9817842222,5.____2355359365,5.1227105795,5.____177856607,5.098596533,5.____1891181988,4.9327118245,4.____4632330777,7.4879538737,4.____8591269625,3.1339054377,5.____8472818275,4.6043306952,3.____3542942377,4.7660145915,6.____6679095357,5.51150886,2.____7404344677,5.9332075344,6.____2019594857,5.266709364,5.____4924174224,5.180577724,3.____0277711677,6.2913260157,4.____2862670877,5.5461328154,5.____5809644644,5.1132029296,5.____1904326724,4.8352505633,4.____9641930171,5.1366240426,7.____0699378037,3.1274712477,5.____1487646306
,5.2717034197,5.____0200090866,3.0911490977,5.____8984613527,5.1973381747,4.__
2427530627,6.7293864957,4.____7943011637,5.1130266607,5.____3948779287,4.7124246547,5.2
186371577,2.9723417287 <tel:9723417287> <tel:9723417287
<tel:9723417287>>,2.3171875277,2.8159853427 <tel:8159853427>
<tel:8159853427
<tel:8159853427>>,__4.7913513947,4.7863347867 <tel:7863347867>
<tel:7863347867
<tel:7863347867>>,3.4531342837,__3.__8161332287,5.8431115757,4.____4873126817,5.6577494097,5.____5867970832,9.4583860946,2.____7784615917,5.4279953797,1.____9376872717,5.0813930177,5.____8860618114,6.2411339874,6.____4536904614,6.0972641874,5.____7247963284,5.9823452114,5.____8316140784,5.2398164977,6.____2963392357,5.5864457124,6.____1599995178,5.2609646384,6.____1012355027,6.4129483756,6.____0056487896,5.0106569884,5.____4239402364,6.1148656496,2.____673828844,4.3332873457,3.____2943586634,4.5834393467,7.____278601561,3.5870893269,3.____3299191554,4.1049776549,5.____9256568037,6.2719334873,6.____2594329923,5.5752581689,5.____6058592867,6.1311384893,6.____4726413519,5.8973941434,6.____2572672069,5.9667442136,5.____3965422637,7.2837623985,6.____9586195092,7.1137641952,6.____3682104908,7.8495628418,7.____2245886958,6.2983788278,7.____3509762248,6.9925366658,6.____5600944468,6.936328733,6.____616665943,6.738732443}")
8 at RETURN QUERY
RETURN QUERY
8 at RETURN QUERY
RETURN QUERY
NOTICE: ids: {}
8 at RETURN QUERY
RETURN QUERY
are not
compatible for
concatenation.
assignment
RETURN QUERY
RETURN QUERY
Thanks for your help. Maybe you need some other
facts about my
table?
The whole script I am excecuting is the following.
I changed some
things, like adding your code and changing the
table name 'ways' to
'cgn_2po_4pgr':
integer)
as
$body$
declare
sql text;
sql2 text;
r record;
r2 record;
i integer;
j integer;
begin
arow from (
FROM
pgr_kdijkstraCost('''||sqlP||'____'', '||r.node||
'||thetbl||' where
id>'||r.id <http://r.id> <http://r.id>
matrixl := '{}';
<http://r.id> <http://r.id> loop
dmatrix[i][r.id <http://r.id> <http://r.id>
<http://r.id>+1]);
end loop;
r2.arow);
array[matrixl]);
Sorry, I don't have a running version of this so this
is somewhat
guess work.
-- ids := ids || r2.id1;
ids := array_cat(ids, r2.id1);
try changing the line above to:
Hi Steve, thank you. Back in office now but I'll try that later at home.
I'll let you know and hopefully I get a good result
Thanks so much.
Carsten
So comment out the old like and rewrite like this.
-Steve
Thanks for all your help Steve,
hope, we're getting closer! Look, not it returns this:
NOTICE: r2:
(34304,"{0,5.3602868897 <tel:3602868897>,4.6782573327
<tel:6782573327>,5.6026971537 <tel:6026971537>,5.2062747797
<tel:2062747797>,5.__0497181017,5.3147719797,5.__0700916462,4.3220066797,4.__8593618137,4.0002255227,6.__055760592,12.5155379824,9.__3170226155,8.72783427270001,5.__9460446587,3.0868131677,5.__1839796057,5.2301666167,2.__1211198847,5.7037465591,2.__7282842677,8.4758437557,11.__1027935904,7.9434273599,7.__8361619299,7.7610621969,7.__4929139614,5.8106133327,5.__9579132527,5.9888473034,6.__5618433959,4.5013708887,1.__9218516244,5.7559805232,5.__2267081177,5.0968196707,4.__8949133597,5.9137964962,4.__2936059427,4.6948533593,3.__4377318427,3.7991617067,4.__1242444467,3.8858731777,3.__9596393887,4.9192685996,4.__6734033563,4.7511846457,4.__4544981945,4.2748693367,3.__411559417,6.6851381985,6.__6744741285,6.9296475385,7.__0136847108,7.1371500908,7.__2719520708,6.6787720528,7.__3530295908,6.8599596928,7.__2216891568,7.4951304208,7.__4404728868,8.1332243958,6.__2736028029,6.963685048,6.__0483763169,5.8653351624,5.__6164044005,6.54979166,5.__8783224469,6.533468297,5.__8553434082
,5.7676662122,6.__267915357,5.22607939
03,3.745459072,6.352470342,5.__4392033722,5.5562602522,5.__3996670482,6.171297855,5.__648779598,5.5653279855,5.__671668653,5.3243595462,5.__879320328,5.859442385,6.__080574272,5.3767159992,6.__170852717,5.3001119472,5.__687201287,5.3573110752,3.__586385579,5.566591422,5.__5104826925,5.916268775,5.__4418422465,5.4037394705,5.__640889612,5.1407657702,4.__5523677017,5.3873769863,3.__601570449,2.978252449,4.__8725960282,4.9817842222,5.__2355359365,5.1227105795,5.__177856607,5.098596533,5.__1891181988,4.9327118245,4.__4632330777,7.4879538737,4.__8591269625,3.1339054377,5.__8472818275,4.6043306952,3.__3542942377,4.7660145915,6.__6679095357,5.51150886,2.__7404344677,5.9332075344,6.__2019594857,5.266709364,5.__4924174224,5.180577724,3.__0277711677,6.2913260157,4.__2862670877,5.5461328154,5.__5809644644,5.1132029296,5.__1904326724,4.8352505633,4.__9641930171,5.1366240426,7.__0699378037,3.1274712477,5.__1487646306,5.2717034197,5.__0200090866,3.0911490977,5.__8984613527,5.1973381747,
4.__2427530627,6.7293864957,4.__7943011637,5.1130266607,5.__3948779287,4.7124246547,5.2
<tel:9723417287>,2.3171875277,2.8159853427
<tel:8159853427>,__4.7913513947,4.7863347867
<tel:7863347867>,3.4531342837,__3.8161332287,5.8431115757,4.__4873126817,5.6577494097,5.__5867970832,9.4583860946,2.__7784615917,5.4279953797,1.__9376872717,5.0813930177,5.__8860618114,6.2411339874,6.__4536904614,6.0972641874,5.__7247963284,5.9823452114,5.__8316140784,5.2398164977,6.__2963392357,5.5864457124,6.__1599995178,5.2609646384,6.__1012355027,6.4129483756,6.__0056487896,5.0106569884,5.__4239402364,6.1148656496,2.__673828844,4.3332873457,3.__2943586634,4.5834393467,7.__278601561,3.5870893269,3.__3299191554,4.1049776549,5.__9256568037,6.2719334873,6.__2594329923,5.5752581689,5.__6058592867,6.1311384893,6.__4726413519,5.8973941434,6.__2572672069,5.9667442136,5.__3965422637,7.2837623985,6.__9586195092,7.1137641952,6.__3682104908,7.8495628418,7.__2245886958,6.2983788278,7.__3509762248,6.9925366658,6.__5600944468,6.936328733,6.__616665943,6.738732443}")
RETURN QUERY
RETURN QUERY
NOTICE: ids: {}
RETURN QUERY
ERROR: function array_cat(integer, integer) does not exist
LINE 1: SELECT array_cat(ids, r2.id1)
HINT: No function matches the given name and argument
types. You might
need to add explicit type casts.
QUERY: SELECT array_cat(ids, r2.id1)
CONTEXT: PL/pgSQL function "pgr_makedijkstramatrix" line 31
at assignment
SQL Status:42883
Hinweis:No function matches the given name and argument
types. You might
Kontext:PL/pgSQL function "pgr_makedijkstramatrix" line 31
at assignment
Function does not exist? Still have an idea?
Thanks
Carsten
end loop;
end loop;
end;
$body$
text, sql text,
$body$
declare
sid integer;
eid integer;
begin
thetbl, sql )
ids as (
asc))-1 as rnum, id
from (
from dm
) foo
t as (
<http://b.id> <http://b.id>
from pgr_tsp(
id=start_id limit
1)::integer,
else (select
rnum
) a,
ids b
where a.id <http://a.id> <http://a.id>
r as (
dm.dmatrix[r.rnum[t.seq+1]+1][____r.rnum[(t.seq+1)%array___length(__r.rnum,
from t, dm, r;
end;
$body$
$body$
begin
target::integer,
length::double
start_id, end_id);
end;
$body$
Maybe you've got another idea?
Thank you
Carsten
Thanks for you help
Carsten
2014-02-20 16:24 GMT+01:00 Stephen Woodbridge
<mailto:woodbri@swoodbridge>.
<mailto:woodbri@swoodbridge>.>______com
<mailto:woodbri@swoodbridge.com>>>>>:
On 2/20/2014 9:41 AM, Stephen
Woodbridge wrote:
Hi Carsten,
The functions at
http://dose.0wnz.at/scripts/________sql/pgroute_tspDijkstra.__sql
<http://dose.0wnz.at/scripts/______sql/pgroute_tspDijkstra.sql>
<http://dose.0wnz.at/scripts/____sql/pgroute_tspDijkstra.sql>\_\_>
<http://dose.0wnz.at/scripts/__sql/pgroute_tspDijkstra.sql>>>
<http://dose.0wnz.at/scripts/sql/pgroute_tspDijkstra.sql>>>>
are not part of pgRouting.
You need to ask this question to
Ivan the
author of the
original
article.
Sorry, Dose was the original author.
You probably need to add some
debug statements
to get a
better
understanding of what the code is
doing. For
example in
pgr_makeDijkstraMatrix before the
statement:
ids := ids || array[r2.id1];
You could try changing this line to:
and see if that fixes the problem.
-Steve
Add:
This should show you the
progression of how
the array
ids is getting
built as it appears to be
compaining about
that in the
error
message.
Hope this helps,
-Steve
On 2/20/2014 9:21 AM, Carsten
Hogertz wrote:
Hi everybody, I am new to
this list and new to
pgrouting.
I found the following TSP example
http://hardwarefetish.com/513-________pgrouting-dijksta-______travelling-__salesman-problem-______tsp-with-__openstreetmap
<http://hardwarefetish.com/513-______pgrouting-dijksta-____travelling-__salesman-problem-____tsp-with-__openstreetmap>
<http://hardwarefetish.com/__513-____pgrouting-dijksta-____travelling-__salesman-problem-____tsp-with-__openstreetmap
<http://hardwarefetish.com/513-____pgrouting-dijksta-__travelling-__salesman-problem-__tsp-with-__openstreetmap>>
<http://hardwarefetish.com/____513-__pgrouting-dijksta-____travelling-__salesman-problem-____tsp-with-__openstreetmap
<http://hardwarefetish.com/__513-__pgrouting-dijksta-__travelling-__salesman-problem-__tsp-with-__openstreetmap>
<http://hardwarefetish.com/513-__pgrouting-dijksta-travelling-__salesman-problem-tsp-with-__openstreetmap>>>
<http://hardwarefetish.com/______513-pgrouting-dijksta-______travelling-salesman-problem-______tsp-with-openstreetmap
<http://hardwarefetish.com/____513-pgrouting-dijksta-____travelling-salesman-problem-____tsp-with-openstreetmap>
<http://hardwarefetish.com/__513-pgrouting-dijksta-__travelling-salesman-problem-__tsp-with-openstreetmap>>
<http://hardwarefetish.com/513-pgrouting-dijksta-travelling-salesman-problem-tsp-with-openstreetmap>>>>
and tried to reproduce the
solution.
Unfortunately I always get an
error message.
My DB is complaining about
one of your
functions.
I got my routing table from
osm2po. The
table has
the following
structure:
1;”id”;”integer”
2;”osm_id”;”bigint”
3;”osm_name”;”character varying”
4;”osm_meta”;”character varying”
5;”osm_source_id”;”bigint”
6;”osm_target_id”;”bigint”;
7;”clazz”;”integer”
8;”flags”;”integer”
9;”source”;”integer”
10;”target”;”integer”
11;”length”;”double precision”
12;”kmh”;”integer”
13;”cost”;”double precision”
14;”reverse_cost”;”double
precision”
15;”x1″;”double precision”
16;”y1″;”double precision”
17;”x2″;”double precision”
18;”y2″;”double precision”
19;”geom_way”;”geometry(________LineString,4326)”
- I installed the functions
as mentioned
via SQL
window in
pgAdmin3
(copy&paste then excecute)
- I create and populate the
my_route table
- When it comes to step 5 and
I try
select id,lon,lat from
pgr_tspDijkstraLen(’my_route’, 1260
) dj, my_route rt where
dj.id2=rt.node;
my DB warns
incompatible arrays
element
dimensions
are not
compatible for
concatenation.
“pgr_makedijkstramatrix”
line 25 at
assignment PL/pgSQL function
“pgr_tspdijkstra” line
8 at
RETURN QUERY
PL/pgSQL function
“pgr_tspdijkstralen”
line 3 at
RETURN QUERY
incompatible
arrays SQL
Status:2202E
element
dimensions are not
compatible for
concatenation.
line 25
at assignment
PL/pgSQL function
“pgr_tspdijkstra” line 8 at
RETURN QUERY
PL/pgSQL function
line 3 at
RETURN QUERY
Do you have any idea what
went wrong? I really
really need your
solutionget working. I would
appreciate a lot.
PS: this text is a copy of
what I wrote on
on the
comment
site of the
blog where I found the solution.
BR
Carsten
_______________________________________________________
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.________org
<mailto:Pgrouting-users@lists
<mailto:Pgrouting-users@lists>.
<mailto:Pgrouting-users@lists>.__>____osgeo.org
<http://osgeo.org> <http://osgeo.org>
<mailto:Pgrouting-users@lists.
<mailto:Pgrouting-users@lists.>____osgeo.org <http://osgeo.org>
<mailto:Pgrouting-users@lists.__osgeo.org
<mailto:Pgrouting-users@lists.osgeo.org>>>>
http://lists.osgeo.org/________mailman/listinfo/pgrouting-________users
<http://lists.osgeo.org/______mailman/listinfo/pgrouting-______users>
<http://lists.osgeo.org/____mailman/listinfo/pgrouting-____users>>
<http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users>>>
<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>>>>
Pgrouting-users@lists.osgeo.______org
Pgrouting-users@lists.osgeo.____org
Pgrouting-users@lists.osgeo.__org
