If all your data is in the database, then you can so queries within your shortest path query.
Look at this workshop example:
SELECT * FROM shortest_path(’
SELECT gid as id,
source::integer,
target::integer,
length::double precision as cost
FROM ways’,
5700, 6733, false, false);
http://workshop.pgrouting.org/chapters/shortest_path.html#core
You can replace start and end point with a query, which is in my example from the same table. But you can modify such a select however you like:
SELECT gid as id,
source::integer,
target::integer,
FROM ways’,
(SELECT min(source)::int FROM ways), (SELECT max(source)::int FROM ways), false, false);
Does this help?
Daniel
On Wed, Oct 12, 2011 at 4:21 PM, dy32 mutQ <dmutq@yahoo.com> wrote:
hello all,
I have a question, how can I get the shortest path with dijkstra algorithm on a map but additionally have another layer or points of interest files from the map.
I set up pgrouting from http://www.utdallas.edu/~ama054000/rt_tutorial.html
for example: I have two layers, hotel (points) and road (polylines)
From hotel A (start point) to hotel B (end point) I can get road 2,3,4
there is any way to integrate these two files (point and line) into one so that for the calculations. In other words, how can I connect two tables, road and hotel to get dijkstra result?
Thanks for your answers
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
