Hello list.
I am experiencing a problem where I am calling 2 pgrouting functions one after another and it is causing the postgresql server (9.1) to crash. (pgrouting version 1.05)
The first function I call is driving_distance, and the second is shortest_path_astar.
Here is the contents of my postgresql log:
terminate called after throwing an instance of ‘std::bad_alloc’
what(): std::bad_alloc
LOG: server process (PID 2587) was terminated by signal 6: Aborted
LOG: terminating any other active server processes
WARNING: terminating connection because of crash of another server process
DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and repeat your command.
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted; last known up at 2012-03-23 21:51:38 EDT
LOG: database system was not properly shut down; automatic recovery in progress
LOG: redo starts at 13/E1D60
LOG: unexpected pageaddr 12/F8ED6000 in log file 19, segment 1, offset 15556608
LOG: redo done at 13/1ED5F90
LOG: last completed transaction was at log time 2012-03-23 21:51:38.166328-04
FATAL: the database system is in recovery mode
LOG: database system is ready to accept connections
LOG: autovacuum launcher started
//Restarted the server and ran my function again
LOG: server process (PID 7716) was terminated by signal 6: Aborted
LOG: database system was interrupted; last known up at 2012-03-23 21:58:57 EDT
LOG: redo starts at 13/1F43238
LOG: unexpected pageaddr 12/F8F76000 in log file 19, segment 1, offset 16211968
LOG: redo done at 13/1F75F28
LOG: last completed transaction was at log time 2012-03-23 22:01:14.86379-04
If I run driving_distance and shortest_path_astar independently of one another there is no problem whatsoever. If I use shortest_path_shooting_star, it works fine. In other words I can replace my call to shorest_path_astar with shortest_path_shooting_star after my driving_distance call and it works.
My use case for this scenario is that I want to first create a drive time polygon, and then calculate distances to points within the polygon from my centroid.
Thanks for any help!
-Steve
