Hi Charles,
I got the following result (note that I am using my own ways data):
12058;12057;121;“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”;24154;24155;121
12059;12058;151;“0105000020E610000001000000010200000005000000880B2FE4B88B41400052503B90883F4000E88B85AD8B41406F818066A4883F407883FE35A58B4140B765EAD6B4883F4050599362988B414070906BE5D3883F4048336500988B4140364027D3D4883F40”;24156;24157;151
Thanks
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Charles Galpin
Sent: Tuesday, September 13, 2011 3:55 PM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] pgrouting installation
I have used pgrouting on Windows 7 so I think this should work (everything else installed via stackbuilder)
What do you get for this query?
select * from ways where source = 24154 or target = 24157
charles
On Sep 13, 2011, at 8:37 AM, Daniel Kastl wrote:
Hi Ali,
I may be wrong, and if there are Windows users out there who know it better, please correct me.
But the binaries for pgRouting were not compiled with Windows 7. They might work, but not necessarily.
Daniel
On Tue, Sep 13, 2011 at 2:39 AM, Ali Taha <ali.taha@ritaj.ps> wrote:
Dear Daniel,
I downloaded them from http://www.pgrouting.org/download.html (windows binaries section pgRouting-1.03_pg-8.4.2)
I have windows 7 OS
Thanks
From: pgrouting-users-bounces@lists.osgeo.org [mailto:pgrouting-users-bounces@lists.osgeo.org] On Behalf Of Daniel Kastl
Sent: Tuesday, September 13, 2011 6:34 AM
On Mon, Sep 12, 2011 at 11:20 AM, Ali Taha <ali.taha@ritaj.ps> wrote:
Dear All,
I am trying to setup and test pgrouting, I followed the setups but it is still not working. If ollowed the following steps:
1- Copay pgrouting libraries to …\pgsql\8.4\lib
From where did you copy them?
Did you compile? Which OS?
Daniel
2- Execute routing_core.sql and routing_core_wrappers.sql
3- Create a newtwork:
a. Added source and target fields
b. Execute Execute assign_vertex_id(‘
’, float tolerance, ‘<geometry column’, ‘’)c. Added indices
d. Added reverse_cost column.
Then I used the following query to retrieve records:
SELECT * FROM shortest_path(‘
SELECT gid as id,
source::integer,
target::integer,
length::double precision as cost
FROM ways’,
24154,
24157,
false, false)
the query executes without errors, but return no data. I checked the table and the records seems OK.
is there a way to validate the database and verify the topology? How to make sure that the pgrouting library (dlls) are installed and working correctly?
Thanks
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.de
