On Mon, Jul 4, 2016 at 10:10 AM, Nico Aliotta <nicoaliotta@gmail.com> wrote:
in the meantime i did
sudo apt-get install postgresql-9.5-pgrouting
and was fine the installation!
Is it complete?
Pgrouting-users mailing list
Pgrouting-users@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
2016-07-04 16:47 GMT+02:00 Daniel Kastl <daniel@georepublic.de>:
First you need to wait until it is published (at this time it still isn’t).
Then I would expect, that you install it the same way as for other platforms:
Daniel
On Mon, Jul 4, 2016 at 11:13 PM, Nico Aliotta <nicoaliotta@gmail.com> wrote:
Ok seems that is still building the package.
How i can install it from my S.O.?
from https://launchpad.net/~georepublic/+archive/ubuntu/pgrouting-unstable/+packages
which command i’ve to use to install only the armhf version?
Currently building on bos01-arm64-019
Georepublic UG & Georepublic Japan
eMail: daniel.kastl@georepublic.de
Web: http://georepublic.info
2016-07-04 16:09 GMT+02:00 Daniel Kastl <daniel@georepublic.de>:
Hi Nico,
Thank you for the link!
I think I was able to trigger a build for “ARM ARMv7 Hard Float”:
Let’s see, if it succeeds.
For now I rebuild the packages for Ubuntu 14.04 and 16.04.
Let me know, if that’s enough for now.
Daniel
On Mon, Jul 4, 2016 at 10:49 PM, Nico Aliotta <nicoaliotta@gmail.com> wrote:
maybe i’ve found how to build an ARM ARMv7 Hard Float (armhf)on launchpad PPA
here it’s the link
http://askubuntu.com/questions/371339/how-to-make-packages-for-arm-in-launchpad
2016-07-04 10:28 GMT+02:00 Daniel Kastl <daniel@georepublic.de>:
Hi Nico,
This is the main page for pgRouting documentation:
http://docs.pgrouting.org/
And this is the page to build the latest release:
http://docs.pgrouting.org/2.2/en/doc/src/installation/build.html
I don’t know how to trigger a build for “arm” on Launchpad PPA.
It only builds for amd64 and i386, but if you know how to do this, please let me know.
Daniel
On Mon, Jul 4, 2016 at 3:23 PM, Nico Aliotta <nicoaliotta@gmail.com> wrote:
MAybe is this?
http://pgrouting.org/docs/1.x/install_ubuntu.html
git clone git://[github.com/pgRouting/pgrouting.git](http://github.com/pgRouting/pgrouting.git) pgrouting
cd pgrouting/
cmake -DWITH_TSP=ON -DWITH_DD=ON .
make
sudo make install
?? and if it's ok is it possible to add in a ppa or add package so that everyone can use it?
2016-07-04 7:19 GMT+02:00 Nico Aliotta <nicoaliotta@gmail.com>:
is it possible to compile pgrouting for raspberrypi3?
that has arm processor? i’musing ubuntu mate 16.04 (arm version)
With sudo apt-get install pgrouting i’m not able.
Where i can find source to compile for arm or packages for ubuntu rpi version?
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
