[pgrouting-users] pgrouting performance on non-spatial dbpedia graph
Hello everyone,
I was posting on the Postgres Slack about the performance I was seeing when routing through a ~20 million edge, ~7 million node dbpedia dump (where only RDF triples from and to dbpedia resource pages are included). They referred me to this mailing list to continue the discussion.
At the time, I was seeing pgr_dijkstra queries on this dataset take around 8 minutes with a huge spike in memory use (to 4GB on this Windows 10 machine) – I have since improved this to about 1.5 minutes (still with the same memory use) after using pgr_contraction to simplify the graph where possible and using the custom Dijkstra query outlined in the Postgres documentation here.
Is this the upper bound of performance improvement I can get without filtering out data? I have tried adding GIN indexes to the contracted-vertex arrays, and partial indexes to the is_new/is_contracted fields, but at most the GIN indexes only helped a bit. I wonder about something like pinning the graph, which is entirely static, in memory so that no data transfer from disk to memory needs to occur. I notice that websites like https://www.sixdegreesofwikipedia.com/ take only a fraction of a second to query the same data AFAIK (they claim 6 million nodes instead of just over 7), though of course I have read the open-source code and see that is leveraging SQLite and application code. But since the pathing logic happens local to the graph itself and not over the network, and pgrouting uses an efficient graph library instead of application code, I don’t see this as a strict disadvantage for pgrouting.
I have also seen the documentation recommending “no more than 1 million nodes” (https://docs.pgrouting.org/latest/en/pgRouting-concepts.html#id61), so I understand if this is a hard limit. Still, I’d like to use Postgres if possible to gain all of its other advantages when building out this project.
Thank you so much for any help anyone can provide, I’m very interested in this problem and excited to hear the nitty, gritty details.
Best,
Sebastian Kazenbroot-Guppy
