Dear All!
I’m using the pgrouting TSP function for the shortest distance calculation. My problem is: if I use different order of magnitude numbers (1.xxx, 10.xxx, 100.xxx, etc.) for “source_id”, my results are SO MUCH different too, while the “source_id” shouldn’t affects the shortest distence results (if I know well)…
What I else tried, I was setting in the pgAdmin conf file the “Genetic Query Optimizer” settings’ parameters in ALL WAYS, but my results was the same, always the same, so NOTHING HAPPENED!
Do you have any ideas to solve my problem?
Thanks for Your help!
All the Best,
Balázs
