Thank you for the response.
I did the change in the function, and the number of intersections decreased to 65 with tolerance parameter 0.000045. It is still not perfect but better.
Thanks again!
________________________________________
From: pgrouting-users-bounces@lists.osgeo.org <pgrouting-users-bounces@lists.osgeo.org> on behalf of pgrouting-users-request@lists.osgeo.org <pgrouting-users-request@lists.osgeo.org>
Sent: Monday, March 16, 2015 8:01 PM
To: pgrouting-users@lists.osgeo.org
Subject: Pgrouting-users Digest, Vol 78, Issue 4
Send Pgrouting-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
pgrouting-users-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Pgrouting-users digest..."
Today's Topics:
1. Re: "pgr_nodeNetwork" function is not working properly
(Stephen Woodbridge)
Message: 1
Date: Mon, 16 Mar 2015 13:22:11 -0400
Subject: Re: [pgrouting-users] "pgr_nodeNetwork" function is not
working properly
Message-ID: <55071143.9040003@swoodbridge.com>
Content-Type: text/plain; charset=UTF-8; format=flowed
This is a known problem and it has a pull request if you want to check
it out:
https://github.com/pgRouting/pgrouting/issues/280
https://github.com/pgRouting/pgrouting/pull/282
-Steve
On 3/16/2015 12:41 PM, Candan Eyl?l Kilsedar wrote:
??Hi everyone,
I am using pgrouting on OpenStreetMap data and I want to node the
network using the function "pgr_nodeNetwork function", however the nodes
are not created correctly. I am importing a large set of data
to PostgreSQL in the following way:BBOX="8.944,45.830, 9.441,46.323"
wget --progress=dot:mega -O "roads_osm_viaregina.osm"
"http://www.overpass-api.de/api/xapi?*[bbox=$\{BBOX\}\]\[@meta\]"osm2pgrouting -file "/home/kilsedar/Desktop/DATA/roads_osm_viaregina.osm" \
-conf "/usr/share/osm2pgrouting/mapconfig.xml" \
-dbname pgrouting-viaregina \
-user postgres \
-host localhost \
-cleanAt this point, if analyze the graph using pgr_analyzeGraph function by
"/SELECT pgr_analyzegraph('ways', 0.001, 'the_geom', 'gid');/" the
result I am getting is the following:NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:
NOTICE: Isolated segments: 86
NOTICE: Dead ends: 8172
NOTICE: Potential gaps found near dead ends: 7419
NOTICE: Intersections detected: *1159*
NOTICE: Ring geometries: 12Later if I run
/"SELECT pgr_nodeNetwork('ways', 0.001, 'gid', 'the_geom');"/
/"SELECT pgr_createTopology(ways_noded, 0.001);"/
/"SELECT pgr_analyzegraph(ways_noded, 0.001//)//;"/
I get the following result:
NOTICE: Isolated segments: 5
NOTICE: Dead ends: 958
NOTICE: Potential gaps found near dead ends: 329
NOTICE: Intersections detected: *5173*
NOTICE: Ring geometries: 12As you can see, the number of intersections increased, instead of
descreasing.NOTE: Somehow, by playing with the tolerance parameter and setting it to
"0.000045" I decreased the number of intersections to 957, and the
complete result is the following:NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:
NOTICE: Isolated segments: 58
NOTICE: Dead ends: 7851
NOTICE: Potential gaps found near dead ends: 68
NOTICE: Intersections detected: 957
NOTICE: Ring geometries: 12In the attachment, I am sending a screenshot of the same data in QGIS,
where the bounding box is "9.265,46.108, 9.276,46.118" and the tolerance
parameter is "0.001". In this screenshot you can see that in some
intersections, nodes are not created. It is trivial to see that red
nodes are the ones that are created after noding.Is it possible to identify the problem, or if the function is running
correctly?Thank you,
Candan Eylul Kilsedar
Pgrouting-users@lists.osgeo.org
End of Pgrouting-users Digest, Vol 78, Issue 4
