Thanks for your response Vicky!
I think I've figured out what the issue is: I'm not too bright!
I was expecting all reachable edges to be selected, but I was wrong.
All usable VERTICES are selected.
Cheers! and Thank you very much!
Jim
Aside:
I had originally built and installed from 0a8be6a
I've since purged the files from
/usr/lib/postgresql/9.3/lib/ and /usr/share/postgresql/9.3/extension/
and built and installed a14a70d which should be HEAD of develop_2_1_0 on
git://github.com/pgRouting/pgrouting.git
On 08/29/2015 12:19 AM, pgrouting-users-request@lists.osgeo.org wrote:
Send Pgrouting-users mailing list submissions to
pgrouting-users@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
or, via email, send a message with subject or body 'help' to
pgrouting-users-request@lists.osgeo.orgYou can reach the person managing the list at
pgrouting-users-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than "Re: Contents of Pgrouting-users digest..."Today's Topics:
1. Re: pgr_drivingdistance problem (Vicky Vergara)
Message: 1
Date: Fri, 28 Aug 2015 23:19:12 -0500
To: pgRouting users mailing list <pgrouting-users@lists.osgeo.org>
Subject: Re: [pgrouting-users] pgr_drivingdistance problem
Message-ID: <BAY177-W30521CFE1B5B17FE5E53BA8A6D0@phx.gbl>
Content-Type: text/plain; charset="iso-8859-1"Hello Jim
I executed your query, I am not getting the same results as you are.
Right now we are in the process of releasing pgRouting 2.1
I used the pgr_DrivingDistance developed for the 2.1 version.
The github branch develop has the latest but its changing a lot during this days.Vicky
Date: Fri, 28 Aug 2015 20:45:45 -0400
To: pgrouting-users@lists.osgeo.org; postgis-users@lists.osgeo.org
Subject: [pgrouting-users] pgr_drivingdistance problemWhen I run pgr_drivingdistance
on an small extract (578 rows) (attached) from an extract
of Pennsylvania's osm pbf file not all edges are being
followed.
I first downloaded the pbf. Then I imported it with osm2pgrouting
osmosis --read-pbf file=pennsylvania-latest.osm.pbf --write-xml pennsylvania-latest.osm
osm2pgrouting -file pennsylvania-latest.osm -conf /usr/share/osm2pgrouting/mapconfig.xml -dbname osm3 -user jim -skipnodes -passwd hunter2and then running
CREATE TABLE smallways AS
SELECT * FROM ways
WHERE ST_DISTANCE(the_geom, ST_GEOMFROMTEXT('POINT(-79.900121 40.448889)', 4326)) < 0.2;and creating the appropriate indices to build a test environment
(the output of which
is the small extract (578 rows)(attached)).
To test pgr_drivingdistance, I did the following:
CREATE OR REPLACE VIEW testing AS
SELECT gid,
the_geom
FROM ( SELECT
seq,
id1 AS vertext_id,
id2 AS gid,
cost
FROM pgr_drivingdistance(
'SELECT gid AS id, source, target,
length AS cost, reverse_cost
FROM smallways',
179103,
0.5,
false,
true) ) t
INNER JOIN smallways USING (gid);and then loading that view into QGIS, I see the following:
Why are some edges not being selected? I initially thought it was
the (source, target) (labels in screenshot) ordering,
but that doesn't seem to be the case, as some edges such as 148517
to the SW of the annotated starting point, seems to be in good
order.
Jim_______________________________________________
Pgrouting-users@lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment.png>
Name: Screenshot - 08282015 - 075732 PM.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment.jpg>
Name: Screenshot - 08282015 - 075732 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20150828/64754341/attachment-0001.png>------------------------------
http://lists.osgeo.org/mailman/listinfo/pgrouting-usersEnd of Pgrouting-users Digest, Vol 83, Issue 16
