Looking at the source code for function _pgr_pointToId() led me to try the following snippets on edge_table:
pgr_test=# select st_distance(the_geom, st_geomfromtext(‘point(1.9999999999 3.5)’, 4326)) as d from edge_table where st_dwithin(st_geomfromtext(‘point(1.9999999999 3.5)’ , 4326), the_geom, 0.001) order by d; d ----------------------- 0 1.00000008274037e-010 (2 rows) pgr_test=# select st_distance(the_geom, st_geomfromtext(‘point(1.9999999999 3.5)’, 4326)) as d from edge_table where st_dwithin(st_geomfromtext(‘point(1.9999999999 3.5)’ , 4326), the_geom, 0.001) order by d limit 1; d — 0 (1 row)
The first row is the “self geometry” to which the point belongs. However, in _pgr_pointToId() there is a “ORDER BY d LIMIT 1”, which would have pick up only
the self geometry and miss the intended one. Could this be the problem? Perhaps there should be a DESC?
On 14 May 2016 at 00:12, <pgrouting-users-request@lists.osgeo.org> wrote:
Send Pgrouting-users mailing list submissions to
pgrouting-users@lists.osgeo.orgTo subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
or, via email, send a message with subject or body ‘help’ to
pgrouting-users-request@lists.osgeo.orgYou can reach the person managing the list at
pgrouting-users-owner@lists.osgeo.orgWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of Pgrouting-users digest…”Today’s Topics:
- Re: Pgrouting-users Digest, Vol 92, Issue 2 (HuanChun Ye)
Message: 1
Date: Sat, 14 May 2016 00:12:15 -0700
To: pgrouting-users@lists.osgeo.org
Subject: Re: [pgrouting-users] Pgrouting-users Digest, Vol 92, Issue 2
Message-ID:
<CADxKYiSvdNhjKveK1Etj2AY79EAMbbEir=qy9Cmo_aKnPQ=qOQ@mail.gmail.com>
Content-Type: text/plain; charset=“utf-8”Hi Regina,
Thanks for your quick response! I upgraded to 2.2.2 using stack builder
with the following results:pgr_sample=# select version(), postgis_full_version(), pgr_version();
version |postgis_full_version
pgr_version
PostgreSQL 9.5.2, compiled by Visual C++ build 1800, 64-bit |
POSTGIS=“2.2.2 r14797” GEOS=“3.5.0-CAPI-1.9.0 r4090” PROJ=“Rel. 4.9.1, 04
March 2015” GDAL=“GDAL 2.0.2, re
leased 2016/01/26” LIBXML=“2.7.8” LIBJSON=“0.12” RASTER |
(2.2.2,pgrouting-2.2.2,544044b,master,1.59.0)
(1 row)But unfortunately the same commands still produce the same results.
Huanchun
- Re: Problem with topology using sample data in the manual
(Regina Obe)
Message: 1
Date: Sat, 14 May 2016 00:24:18 -0400
To: “‘pgRouting users mailing list’” <pgrouting-users@lists.osgeo.org>
Subject: Re: [pgrouting-users] Problem with topology using sample data
in the manual
Message-ID: <000001d1ad98$7b662120$72326360$@pcorp.us>
Content-Type: text/plain; charset=“utf-8”Quick note.
There were some issues in pgRouting 2.2.0 released which this may be one
of them. I pushed up pgRouting 2.2.2 in stackbuilder last week for
PostgreSQL 9.5 x windows 64-bitIf you reinstall PostGIS bundle from stackbuilder and then do a
ALTER EXTENSION pgRouting UPDATE;
You should get the new version.
For others on windows, sorry haven’t had a chance to repackage. I do have
binaries you can get from here - http://postgis.net/windows_downloads/In the unreleased section – look for in respective pg version folder
pgrouting-pg95-binaries-2.2.2w64gcc48.zip <
http://winnie.postgis.net/download/windows/pg95/buildbot/pgrouting-pg95-binaries-2.2.2w64gcc48.zipWhere the 95, w64 will change depending on which version of PostgreSQL you
are running.These will be the same versions I’ll be pushing up.
Regina
From: Pgrouting-users [mailto:pgrouting-users-bounces@lists.osgeo.org] On
Behalf Of HuanChun Ye
Sent: Friday, May 13, 2016 11:57 PM
Subject: [pgrouting-users] Problem with topology using sample data in the
manualI am working through the examples in the manual (v2.2) using the sample
data, but encountered a problem with topology, as described below. I
apologize for the verbosity, but I want to show the exact steps leading to
the problem, starting with just after importing the sample data:pgr_sample=# select * from edge_table;
id | dir | source | target | cost | reverse_cost | x1 | y1 | x2
| y2 | the_geom----±----±-------±-------±-----±-------------±----±----±---------------±----±----------------------------------------------------------------------------------
1 | B | | | 1 | 1 | 2 | 0 |
2 | 1 |
010200000002000000000000000000004000000000000000000000000000000040000000000000F03F2 | TF | | | -1 | 1 | 2 | 1 |
3 | 1 |
0102000000020000000000000000000040000000000000F03F0000000000000840000000000000F03F3 | TF | | | -1 | 1 | 3 | 1 |
4 | 1 |
0102000000020000000000000000000840000000000000F03F0000000000001040000000000000F03F4 | B | | | 1 | 1 | 2 | 1 |
2 | 2 |
0102000000020000000000000000000040000000000000F03F000000000000004000000000000000405 | FT | | | 1 | -1 | 3 | 1 |
3 | 2 |
0102000000020000000000000000000840000000000000F03F000000000000084000000000000000406 | B | | | 1 | 1 | 0 | 2 |
1 | 2 |
01020000000200000000000000000000000000000000000040000000000000F03F00000000000000407 | B | | | 1 | 1 | 1 | 2 |
2 | 2 |
010200000002000000000000000000F03F0000000000000040000000000000004000000000000000408 | B | | | 1 | 1 | 2 | 2 |
3 | 2 |
01020000000200000000000000000000400000000000000040000000000000084000000000000000409 | B | | | 1 | 1 | 3 | 2 |
4 | 2 |
010200000002000000000000000000084000000000000000400000000000001040000000000000004010 | B | | | 1 | 1 | 2 | 2 |
2 | 3 |
010200000002000000000000000000004000000000000000400000000000000040000000000000084011 | FT | | | 1 | -1 | 3 | 2 |
3 | 3 |
010200000002000000000000000000084000000000000000400000000000000840000000000000084012 | FT | | | 1 | -1 | 2 | 3 |
3 | 3 |
010200000002000000000000000000004000000000000008400000000000000840000000000000084013 | FT | | | 1 | -1 | 3 | 3 |
4 | 3 |
010200000002000000000000000000084000000000000008400000000000001040000000000000084014 | B | | | 1 | 1 | 2 | 3 |
2 | 4 |
010200000002000000000000000000004000000000000008400000000000000040000000000000104015 | B | | | 1 | 1 | 4 | 2 |
4 | 3 |
010200000002000000000000000000104000000000000000400000000000001040000000000000084016 | B | | | 1 | 1 | 4 | 1 |
4 | 2 |
0102000000020000000000000000001040000000000000F03F0000000000001040000000000000004017 | B | | | 1 | 1 | 0.5 | 3.5 |
1.999999999999 | 3.5 |
010200000002000000000000000000E03F0000000000000C4068EEFFFFFFFFFF3F0000000000000C4018 | B | | | 1 | 1 | 3.5 | 2.3 |
3.5 | 4 |
0102000000020000000000000000000C4066666666666602400000000000000C400000000000001040(18 rows)
pgr_sample=# select pgr_createTopology(‘edge_table’, 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_createTopology(‘edge_table’, 0.001, ‘the_geom’, ‘id’,
‘source’, ‘target’, rows_where := ‘true’, clean := f)NOTICE: Performing checks, please wait …
NOTICE: Creating Topology, Please wait…
NOTICE: -------------> TOPOLOGY CREATED FOR 18 edges
NOTICE: Rows with NULL geometry or NULL id: 0
NOTICE: Vertices table for table public.edge_table is:
public.edge_table_vertices_pgrNOTICE: ----------------------------------------------
pgr_createtopology
OK
(1 row)
pgr_sample=# select pgr_analyzeGraph(‘edge_table’, 0.001);
NOTICE: PROCESSING:
NOTICE:
pgr_analyzeGraph(‘edge_table’,0.001,‘the_geom’,‘id’,‘source’,‘target’,‘true’)NOTICE: Performing checks, please wait …
NOTICE: Analyzing for dead ends. Please wait…
NOTICE: Analyzing for gaps. Please wait…
NOTICE: Analyzing for isolated edges. Please wait…
NOTICE: Analyzing for ring geometries. Please wait…
NOTICE: Analyzing for intersections. Please wait…
NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:
NOTICE: Isolated segments: 2
NOTICE: Dead ends: 7
NOTICE: Potential gaps found near dead ends: 1
NOTICE: Intersections detected: 1
NOTICE: Ring geometries: 0
pgr_analyzegraph
OK
(1 row)
pgr_sample=# select pgr_nodeNetwork(‘edge_table’, 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_nodeNetwork(‘edge_table’, 0.001, ‘id’, ‘the_geom’, ‘noded’,
‘’, f)NOTICE: Performing checks, please wait …
NOTICE: Processing, please wait …
NOTICE: Splitted Edges: 2
NOTICE: Untouched Edges: 16
NOTICE: Total original Edges: 18
NOTICE: Edges generated: 4
NOTICE: Total New segments: 20
NOTICE: New Table: public.edge_table_noded
pgr_nodenetwork
OK
(1 row)
pgr_sample=# select pgr_createTopology(‘edge_table_noded’, 0.001);
NOTICE: PROCESSING:
NOTICE: pgr_createTopology(‘edge_table_noded’, 0.001, ‘the_geom’, ‘id’,
NOTICE: -------------> TOPOLOGY CREATED FOR 20 edges
NOTICE: Vertices table for table public.edge_table_noded is:
public.edge_table_noded_vertices_pgrNOTICE: ----------------------------------------------
pgr_createtopology
OK
(1 row)
pgr_sample=# select pgr_analyzeGraph(‘edge_table_noded’, 0.001);
NOTICE: PROCESSING:
NOTICE:
pgr_analyzeGraph(‘edge_table_noded’,0.001,‘the_geom’,‘id’,‘source’,‘target’,‘true’)NOTICE: Performing checks, please wait …
NOTICE: Isolated segments: 1
NOTICE: Intersections detected: 0
pgr_analyzegraph
OK
(1 row)
pgr_sample=# SELECT a.*
pgr_sample-# FROM edge_table_noded a, edge_table_noded_vertices_pgr b,
edge_table_noded_vertices_pgr cpgr_sample-# WHERE a.source=b.id <http://b.id> AND b.cnt=1 AND a.target=
c.id <http://c.id> AND c.cnt=1;id | old_id | sub_id | source | target |
the_geom----±-------±-------±-------±-------±-----------------------------------------------------------------------------------
20 | 17 | 1 | 17 | 18 |
010200000002000000000000000000E03F0000000000000C4068EEFFFFFFFFFF3F0000000000000C40(1 row)
So the original node id 17, which is a nearly touching T-intersection,
remains isolated. This is in contrast to the output shown in the manual,
which shows the following:SELECT pgr_analyzegraph(‘edge_table_noded’, 0.001);
NOTICE: PROCESSING:
NOTICE:
NOTICE: Performing checks, pelase wait…
NOTICE: Isolated segments: 0
NOTICE: Dead ends: 6
NOTICE: Potential gaps found near dead ends: 0
pgr_createtopologyOK
(1 row)I tried the following but none helped:
increasing the value of tolerance up to 0.5
setting the SRID of the geometry column
converting data to .osm file and run osm2pgrouting
I am using the following versions on Windows 10 64-bit PC:
version |
pgr_version-------------------------------------------------------------±----------------------------------------------------------------------------------------------------------
March 2015” GDAL="GDAL 2.0.2, released 2016/01/26" LIBXML=“2.7.8” LIBJSON=“0.12” RASTER |
(2.2.0,pgrouting-2.2.0,afc622e,master,1.59.0)(1 row)
Thanks in advance for your help!
An HTML attachment was scrubbed…
URL: <
http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160514/0d095906/attachment.html
Subject: Digest Footer
Pgrouting-users@lists.osgeo.org
End of Pgrouting-users Digest, Vol 92, Issue 2
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160514/6ef9660c/attachment.html>
End of Pgrouting-users Digest, Vol 92, Issue 3
